RS4 K04 parts numbers......questions (edited)
Since they are out of stock, I'm looking to find all part numbers for items in ECS Tuning's K04(only) kit:
<img src="http://www.ecstuning.com/stage/images/product/iadmin/800_x450.jpg"> From ECS website: <i>Kit comes with: -New RS4/KO4's -New OEM Intake Pipe Kit -New turbo studs -All new OEM gaskets that is needed for installation</i> I have <b>BOLDED</b> all the part numbers I think are in this kit (needed parts for k04 install); could one of you K04-savy guys verify this for me? <u>RS4 part numbers (from FunkWeasel)</u> <b>RS4 K04 Turbocharger, left 078 145 703 M (5304 988 0025) RS4 K04 Turbocharger, right 078 145 704 M (5304 988 0026) induction pipe RH (Turbo inlet pipe) 078133610H induction pipe LH (Turbo inlet pipe) 078133609H induction pipe RH (up-pipe) 078133610G induction pipe LH (up pipe) 078133609G induction pipe connecting hose - 2 078 145 719 P</b> clutch throwout bearing 01E 141 165 B RS4 MAF sensor-bosch 077 133 477 K RS4 Airbox 078 133 837 BQ RS4 Airbox-MAF housing O-ring N 909 643 01 MAF housing Torx head screws - 2 N 104 541 01 RS4 fuel pump 8D0 201 319 C RS4 Y-pipe 078 133 351 F RS4 maf-y-pipe hose 078 129 627 P RS4 Y-pipe to inlet pipe hose-left 078 133 241 G RS4 Y-pipe to inlet pipe hose-right 078 133 241 H <b>turbo-downpipe gaskets - 2 8D0 253 115 F</b> thick copper gaskets - 2 N 013 814 4 thin copper gaskets - 4 N 013 818 2 coolant line crush gaskets - 8 <b>turbo-downpipe nuts - 8 N 903 690 01 turbo-downpipe studs - 8 N 907 787 01 turbo oil line gaskets - 2 058 145 757 B</b> rs4 fuel injectors - 6 078 133 551 BJ small silver washers - 4 N 013 807 6 <b>exhaust manifold to turbo gaskets - 2 078 145 039</b> I know Avalon has a basic kit in stock, but I'd like to know this info anyways. |
that looks right
here's my list
0025) RS4 K04 Turbocharger, right 078 145 704 M (5304 988 0026) induction pipe RH (Turbo inlet pipe) 078133610H induction pipe LH (Turbo inlet pipe) 078133609H induction pipe RH (up-pipe) 078133610G induction pipe LH (up pipe) 078133609G induction pipe connecting hose - 2 078 145 719 P clutch throwout bearing 01E 141 165 B RS4 MAF sensor-bosch 077 133 477 K RS4 Airbox 078 133 837 BQ RS4 Airbox-MAF housing O-ring N 909 643 01 MAF housing Torx head screws - 2 N 104 541 01 RS4 fuel pump 8D0 201 319 C RS4 Y-pipe 078 133 351 F RS4 maf-y-pipe hose 078 129 627 P RS4 Y-pipe to inlet pipe hose-left 078 133 241 G RS4 Y-pipe to inlet pipe hose-right 078 133 241 H turbo-downpipe gaskets - 2 8D0 253 115 F thick copper gaskets - 2 N 013 814 4 thin copper gaskets - 4 N 013 818 2 coolant line crush gaskets - 8 turbo-downpipe nuts - 8 N 903 690 01 turbo-downpipe studs - 8 N 907 787 01 turbo oil line gaskets - 2 058 145 757 B rs4 fuel injectors - 6 078 133 551 BJ small silver washers - 4 N 013 807 6 exhaust manifold to turbo gaskets - 2 078 145 039 injector clips - 6 077 906 037 A |
no need for...
thin copper gaskets - 4 N 013 818 2 coolant line crush gaskets - 8 small silver washers - 4 N 013 807 6 ??? |
yeah, thats pretty much the exact same as mine...
I'm looking for all the necessary part numbers for a K04 <u>only</u> install. I was hoping someone could tell me if all the part numbers i put in <b>bold</b> were all that was necessary for the install.
yeah, but i thought you were just double checking part numbers?
That's about what my box from OCT/Strat looked like.
Re: yeah, but i thought you were just double checking part numbers?
I'm trying to make a list of all part numbers needed for a basic K04s install. First, I went to ECS' website and found what they said to be everything needed for the install. I then cross referenced that with the part numbers from FunkWeasel's post. Basically, I want a packing list of ECS's basic K04 kit WITH corresponding Audi part numbers.
Do my bolded items meet that description? More root question: can i rummage the internet with those bolded part numbers and put together an exact replica of the ECS kit? |
are you going to try and find all the parts seperately?
i'd do this....buy the K04 isntall kit from ECS (with gaskets, crush washers, ect...) buy the turbos, and buy the inlet pipe kit. But maybe i'm missing the point of what you're doing :/
Jim, I have KO4's and Inlet tubing in stock...email me.
