S4 Bose radio codes - 00117?
My dealer just replaced my radio and looks like they forgot to re-code the radio as a Bose head unit.
After searching, I've found several codes, but I'm leaning toward 00117. Is this the correct coding for a Bose 2000 S4?
Thanks,
Thanks,
some feel it sounds better without bose coding...
<ul><li><a href="http://bostonaudi.proboards.com/index.cgi?board=general&action=display&num=1013528 834">http://bostonaudi.proboards.com/index.cgi?board=general&action=display&num=1013528 834</a</li></ul>
I have mine set to 00003. Sounds better than it did as Bose.
I have an aftermarket setup and now that the eq and amps are getting a cleaner, flatter signal, i have more bass, crisper highs and clearer mids. i didn't think i'd hear a difference, but i did!
Pretty easy... :)
Click on Radio --> Recode. Then enter in the 00003 value and click "Do It".
Need to turn off the ignition and back on again in order for it to take effect. Might want to jot down your previous settings in case you would want to revert them. But you won't.
mmart6545
06-09-2003 11:16 AM
MC
01-31-2000 01:00 PM
