S4 Oil Temp. Is 320 too high?
Hi Gang,
I was at a track event last weekend in California and it was hot, (over 100 in the shade). While on the track I saw my oil temp rise such that I became nervous.
I always thought that an oil temp over 300 spelt potential disaster so when I saw this temp I quit running the car hard so it could cool down. IOW I went from being a fast mover to a moving obstacle!
However, the oil temp red zone on the S4 doesn't become red until 350 which begs the question: What is a safe high temp for the S4?
Any thoughts?
Cheers ... Phil Usher
Any thoughts?
Re: S4 Oil Temp. Is 320 too high?
I would hope you were running synthetic oil. If so 320' is do-able but not the best for your car. I would remove all the "plastic" pieces from the engine and run "water-wetter" in the cooling system. Reduce the amount of anti-freeze in the coolant as well. If you are running with a chip make sure your exhaust is as free flowing as possible. Down-pipes really help remove the heat away from the turbos which will also help lower the oil temp. I think we saw 325' on mine running in similiar conditions when I first got the car, but that was before we did all of the above. Still, in 100' heat on a track for any period of time with turbos "cooking" I would not be surprised to see 320' temps. I would say anything over 325' and I would pull in. That would give you a 25' cushion. I would also run 5w40 synthetic to help in those high temps. I no longer do track-days when the temps are over 100'.
That could be deadly.
Is that at speed or at idle? If at idle, you are probably OK, but at any speed you have a problem. Oil pressure required to keep the main & rod bearings 'floating' on an oil film is a function of crank journal diameter and RPM. At moderate to high RPM's, anything under 30-40 psi will likely cause the bearings to run directly on the metal journal (without the oil film). This will result in bearing damage.
I would think the ECU would warn me of that....
I also think there could be something wrong with the hosing of the oil pressure gauges too. When I start the car, its at a woopping 40psi! And slowly dies down to 30psi when warmed.
