See that clamp in the middle of this y-Hose? what do you need to make it tight?
Old 05-17-2002, 11:19 AM
New Member
CasaS4's Avatar
Default See that clamp in the middle of this y-Hose? what do you need to make it tight?
<center><img src="http://pictureposter.audiworld.com/32515/yhose_red.jpg"></center><p>Im installing it today but I dont know how to ake this clamp tight
Old 05-17-2002, 11:21 AM
Senior Member
Kent L's Avatar
Default Tool that looks like...
this:
<img src="http://biz.guidesmart.com/retail/sampleshardware/pliers.jpg">
Old 05-17-2002, 11:30 AM
AudiWorld Expert
CraigB's Avatar
Default ...or a clamp that looks like...
this (only much smaller):
<img src="http://www.compcams.com/gatorbrand/clamp.gif">
Old 05-17-2002, 11:36 AM
frank's Avatar
no, that's not a good solution
Old 05-17-2002, 11:41 AM
AudiWorld Expert
CraigB's Avatar
Please explain
Old 05-17-2002, 12:00 PM
BaysideRS4's Avatar
Default for $15-20 you can order it from mcmaster.com
the side version is probably better for that Where are you located?
Old 05-17-2002, 12:02 PM
BaysideRS4's Avatar
Default all of those corrugations bother me for such a piece at the TBB
I would rather use the stepless ear clamp, which is what is stock and has less going on in the inner ring.
Old 05-17-2002, 12:35 PM
AudiWorld Expert
CraigB's Avatar
Default What about the other 3 clamps on the TBB that are the screw type?...
The above pic was just a representation of a screw type clamp. There are screw clamps that don't have the corrugations, if that bothers you.
Old 05-17-2002, 12:48 PM
BaysideRS4's Avatar
Default sure, e.g., those pictured there look like what you are referring to
also the revised stock screw clamps on the TBB seem ok or better. I'm not convinced its the revised clamps tearing now so much as the TBB contributing to it.
I just don't like unnecessary metal placed against a pressurized hose. Those screw clamps on my boat engine tear into the hoses to some extent, and there isn't pressurized water flowing through those hoses. All I was saying is a semi-expandable boot that is subject to high temps and charged air should probably have smoother clamps on them, like the stock ones or the MTM ones there or the ones AMS provides.
The MTM material is probably so reinforced that it may not be that much of an issue, but I wouldn't risk it.
Old 05-17-2002, 01:15 PM
frank's Avatar
Default screw clamps of that size, tend to form an oval when tighten, bad sealing
that's why there are many more ear-clamps, in that small a size than screw-clamps
Quick Reply: See that clamp in the middle of this y-Hose? what do you need to make it tight?
