slight hesitation at WOT after shifts EQUALS...
"tear"
"tare" is used when you are weighing things ;-)
so your hesitation is one you floor it, it takes a second before the car goes? you sure you're not just noticing the turbo lag?
(corrected), i get acceleration, then mild hesitation...
so i get some "umph" after stomping on it...then less than 1/2 a second later i get the hesitation, then the "umph" comes back on 100%.
Any boost leak could result in these symptoms
If you have aftermarket BPV's put the stock ones back in and see what happens.
Check the TBB and F-hose as well...
Do you have a VAG tool? Any trouble codes?
Does the "two-stage" acceleration seem more pronounced in first-gear launch or pretty much the same in any gear?
