Slipping clutch or something else i cant tell..
Ok i recently put in the CM stag3/4 clutch and resurfaced OEM flywheel. broke everything in very easy for about 600-750 miles. Now i got the same kinda of "slip" when under hard acceleration. mostly WOT.
However when i punch it it seems to slip quick grab slip grab slip grab and then eventually grab hard and i get full power. But also when this happens i never smell ANY burning clutch and most of the time when it does what it does bad, the CEL flashes a couple times and then goes back to its usuall. Last time i check my only codes were rear o2 sensor code and a bad ecm code cause of a ECU issue. Any1 got any suggestions? right now im at the point of buying a LWFW and going back in and checking out the situation. There is ~1500 miles on the clutch now. But something else tells me it might not be the clutch? Could bad misfires cause a slipping type feel like that? or maybe the fuel is cutting or something, but i also dont think its that because the RPMS dont dip. |
cant help you without logs - i doubt the almighty CM is slipping
2nd. need some logs.
yes i have tomorrow off am ognna work on getting some loggin done, but my buddy with vag is up north
