Small Coolant Leak On Left Turbo
I have a small coolant leak on the top left banjo fitting on the left turbo.
There is a hex extension between the top of the turbo and the banjo fitting itself. The leak is actually where the hex extension meets the top turbo body. There is also an X cut in the top of the banjo fittings bolt.
I have the exhaust out of the car right now to do a clutch replacment. It seems to me that there is no good way to get onto the fitting to tighten or remove it to replace the sealing washer.
Does anyone have any tips on fixing this leak?
Left top coolant banjo bolt sould be able to tighten from top , remove?move coolant jug
I had a leak on my pass side turbo bajo bolt and made a special tool .I cut a 12 piont thin wrecg in haf and welded a 3/8 socket to the 12 piont side worked great ..
Can you just tighten it down further? Sorry, not much help...
I had a small coolant leak and tightening the bolt solved it...but I think it was from a different bolt than you describe (passenger side too)....
<img src="http://pictureposter.audiworld.com/41738/turboleak1.jpg">
<img src="http://pictureposter.audiworld.com/41738/turboleak2.jpg">
Get an engine bridge ($125), remove bumper, wheel axles and loosen sub-frame bolts
then lower engine a few inches and reach in through the wheel well. Use a long-long socket wrench extension and 17mm socket to tension the banjo on the top.
It's best to do this after heat cycle i.e. turbo was hot then cold again.<ul><li><a href="http://www.amazon.com/s/ref=nb_ss_auto/104-0464982-9889537?url=search-alias%3Dautomotive&field-keywords=engine+transverse+bar&Go.x=0&Go.y =0&Go=Go">Transverse Bar</a></li></ul>
Re: Get an engine bridge ($125), remove bumper, wheel axles and loosen sub-frame bolts
VR Life,
That makes sense. Why do I need to remove the bumper cover? Also the tranny and exhaust is out of the car right now. I am almost to the point of dropping the engine a few inches.
Swank4
11-02-2006 11:45 AM
bitjockey (bum)
09-21-2005 03:26 PM
AudiS4guy - NorCal
10
11-22-2004 09:02 PM
Richie-S4
04-17-2004 12:00 PM
