So whatever happened with that 3/4 vs. full throttle test?
I'm very happy with my 50 cent fix. I did a few 1/4 mile runs yesterday...
...which were in the low 14s. That's good considering the high humidity, full tank of gas, 19s, etc... Also my trap speeds were pretty good, 100.1mph and 99.5mph respectively. Remember, I have no performance mods except a Borla exhaust. Chip, DPs, and SS...I'm still debating the warranty issue...
So my conclusion is:
1) There is very little to no difference between the 3/4 throttle solution and full throttle when accelerating from standstill because I yield similar, if not the same numbers.
2) There is NO delay with the 3/4 Throttle solution for daily driving while there IS a 0.5 to 1 second delay when you go WOT without any solution.<ul><li><a href="https://forums.audiworld.com/s4/msgs/475645.phtml">https://forums.audiworld.com/s4/msgs/475645.phtml</a</li></ul>
Wouldn't VAGCOM capture the "difference" between two runs: WOT vs. 3/4 ?Ultimately does it come down
LMDA1
09-10-2001 03:23 PM
Brian@P.O.G.
25
09-05-2001 07:01 PM
