Sounds like a torn wastegate line? Boost flutter under part throttle, inconsistent acceleration...
overboosting, especially in between shifts. I am running a MBC only.
Lately, my car has seemed sluggish in the mid rpms and once I hit about 5k it takes on like normal. Just pressure tested, no boost leaks.
I saw a spike of 26psi recently and back down to normal in between a 2nd to 3rd shift.
Also, the other day under WOT, I was only able to build 8-10 psi, but when I shifted, back up to 22psi.
I can see and feel the boost fluttering between 6-10psi, back and forth, at 1/4 to 1/2 throttle.
Any one have ideas? From searching I think it might be torn wastegate lines. Thanks.
