Spark plug questions
I searched the archives, but there is a lot of conflicting information.
I need to change the plugs in my stock 02. Whats the best plug to use and where can I get them online. Also, do I need to change the boot as well?
Thanks
Thanks
Concensus is Bosch F5DP0R for chipped...
But I've had equally good results with Denso IK22. Now I have F5DP0R.
Stock car should run stock plugs... figured everone was chipped here.
Your ignition is coil on plug, nothing else needs replacement
PFR6Q is stock plug, from NGK. They are laser platinum and run about $12 ea. depending on where you
get them from. NGK also makes an Iridium plug that is significantly cheaper, but the stockers are just about the most expensive plug going.
big_anthoiny
11-16-2008 08:46 AM
ljun
12-19-2007 10:10 AM
A4edge
11-21-2003 09:23 AM
Clout
05-21-2002 08:28 AM
