Is there anyway to tap into the factory EGT sensors for Zeitronix?
iirc you plug that in by the ecu .. i remember seeing a diagram/pic of all the wires/colors
i first thought you were going to try and replace the wideband with the stock egt sensor.
Nope!
Zeitronix uses K-Type thermocouples (Ni-Cr/Ni-Al), factory EGT sensors are N-Type thermocouples (Ni-Cr-Si/Ni-Si). They're not compatible.
If you want to read the factory EGT sensors, you'll need to tap into one of both the outputs from the EGT electronic modules (at the back of the intake manifold) and read it as a 0-5v signal. 4.8v is 1035 degrees, 0.1v is 945. They don't read anything below 945 by the way.
HTH,
Mihnea
HTH,
Mihnea
Sorry for TJ ;)
pai prin fata usii trec in fiecare zi muhahahaha
fac ghinie cica, stresat ca dracu cu diverse dar incep sa fac planuri sa trec pe la voi cindva in cur-ind
parintii de-abia au plecat spre tara, se duc la mare
inliner311
06-13-2007 11:15 AM
