is there an OEM front 330mm rotor application?
<center><img src="http://pictureposter.audiworld.com/5987/dsc_5695.jpg"></center><p>long story short I have an MTM/Brembo front brake kit and I am in need of new rotors. I would like to run an oem spec rotor if I could instead of the two piece rotors$$$. I test fit stock S4 rotors and they are the correct offset but about 10mm small. Stock is 321 correct? Is there an oem 330 rotor that I could use? Thanks!
do you need to replace the entire 2-piece rotors? the actual rotor should not be that bad to
replace because you don't have to replace the hats unless they are broken. I've never heard of someone wanting to remove a BBK setup for stock unless they are selling and the price difference to replace should not be enough to make up for what you'd lose.
OT: Steve can you confirm if the wheels in the link are et 20 9.5, or et20 10, inches wide?
and what tire size are you running on those?<ul><li><a href="http://pictureposter.audiworld.com/5987/100_1770.jpg">http://pictureposter.audiworld.com/5987/100_1770.jpg</a</li></ul>
I also found that 034 sells machined RS2 brake caliper brackets to allow for smaller rotors
Wonder if I can just do the same with the brackets I have to work with an S8 rotor?
