Are these good enough to use with my RS4 IC's or should I get the APR ones?
<center><img src="http://pictureposter.audiworld.com/57294/rs4tube.jpg"></center><p>They came with my RS4 IC's and seem decent quality.
Ah you are talking about the upper pipes... forgot about those.
On the lower end you need a longer aluminum pipe to replace one of the S4 ones if you use the RS4 hoses. On the upper part of mine I've got standard silicone couplers so I didn't realize those were larger diameter as well.
-Dave Pramanik
-Dave Pramanik
Correct Passenger Side lower RS4 pipe is longer. The Lower boots will work OK...
The uppers howerever will not fit onto the OEM Upper Charge pipe, you will need to make a coupling that acts as an extension and use two silicon couplers
-or-
use the APR hoses =)
-or-
