For those with 400+ hp at the WHEELS (500+ at the crank), how much boost and what kind of feul used?
Old 04-14-2005, 02:17 PM
New Member
/\UDI~o~phile's Avatar
Default For those with 400+ hp at the WHEELS (500+ at the crank), how much boost and what kind of feul used?
It seems that 20lbs of boost with pump gas cant get figures that high.
Old 04-14-2005, 02:24 PM
AudiWorld Expert
nyet's Avatar
Default 20psi and 94-95 should get you there on stg3
91oct, bleh. you know the story
Old 04-14-2005, 02:28 PM
New Member
define stg 3
Old 04-14-2005, 02:40 PM
AudiWorld Expert
nyet's Avatar
k04, fueling, dps
Old 04-14-2005, 02:45 PM
New Member
Default I've done all that and I've pulled only 340 on the dyno. Car runs very smooth, a/f ratio looks good
and the car is running high 12s. Needless to say the numbers I am getting and those I read about on the board dont add up.
Old 04-14-2005, 02:48 PM
AudiWorld Expert
nyet's Avatar
Default some setups are faster than others
340whp isn't bad (esp. if that is a mustang number)
try race gas, you should see 400.
Old 04-14-2005, 02:50 PM
New Member
that was on a dyno dynamics.
Old 04-14-2005, 02:55 PM
EdyJun's Avatar
How is your timing ?
Old 04-14-2005, 02:57 PM
New Member
Default I was running 96 so I assume the ECU wasnt pulling it back to much, it was 90 degrees out though so
Im sure it pinged a little.
Old 04-14-2005, 03:12 PM
Junior Member
oldyellar's Avatar
Default check out the stage 3 on this site.........
this was on a Dyno Dynamics also......he definetly needed to lemmi with it.<ul><li><a href="http://maxhawk.bravepages.com/car/Dyno-010805/">http://maxhawk.bravepages.com/car/Dyno-010805/</a</li></ul>
Quick Reply: For those with 400+ hp at the WHEELS (500+ at the crank), how much boost and what kind of feul used?
