Throttle issues with ABT/AMS A-box?
Old 03-31-2005, 12:02 PM
New Member
Boston s4 sixspd's Avatar
Default Throttle issues with ABT/AMS A-box?
I am a stage 2 A box car with the ABT/AMS chip and my car wont allow me to rev over the 5000 RPM mark regardless of whether the car is under boost or not i.e. I can be at any percent throttle and the car just won't do it. Of note though my instrument cluster is dying I believe. The speedometer has stopped working, the gas gauge does not work properly when below half and the coolant gauge does not sit right in the middle anymore when the car is all warm. Not sure if this could have anything to do with it. Any help is appreciated.
Old 03-31-2005, 12:08 PM
S4_4MY30'S's Avatar
i'm afraid that's not TC and i have no clue what it could be.SORRY.
Old 03-31-2005, 12:09 PM
Member
AudiS4guy - NorCal's Avatar
Default you got some issues man. Get those fixed! Anyway, when you say throttle cut
not sure what you mean. When you go WOT does your car loose power after you hit 5000 rpms? Not sure whats going on. If you have VAG then i'd log block 3 and see what your throttle is doing @ WOT.
Old 03-31-2005, 12:16 PM
reefer_bob's Avatar
Do you have a CEL?
Old 03-31-2005, 12:57 PM
New Member
Full power to 5000rpm's, car wont go past there regardless of amount of throttle applied
Old 03-31-2005, 12:59 PM
New Member
Almost like a fuel cutoff, I do have a CEL, been on before problem started too
Old 03-31-2005, 01:02 PM
DarinS4Turbo's Avatar
Default Yeah, like a premature rev limiter - unless your tach is actually reading wrong too
Check codes or swap in another ECU from a buddy to rule that out.
Old 03-31-2005, 01:07 PM
New Member
Exactly, dam CEL came on after Brians garage replaced clutch and FW assembly
Twelve Rings
11
07-28-2005 07:19 PM
Rob O
11-07-2003 05:47 PM
Milpitas2.7T
13
10-17-2002 12:02 PM
WoostaS4
09-17-2002 06:07 PM
riceboy22
05-29-2002 05:52 AM
Quick Reply: Throttle issues with ABT/AMS A-box?
