Torque Converter on Tip '00 S4
Old 01-09-2004, 06:09 PM
  #11
Senior Member
Skydive@AI's Avatar
Default Costs associated with the transmission...
$2,650 - Spare Trans (Reclaimed on sale of stock trans.)
$ 175 - Freight to Level10 (CA -> NJ)
$4,400 - Level10 Work (Valve bodies, Torque Convertor, Clutch Bands, etc.)
Return freight to California is included in the cost of the Level10 work.
I'll recover the cost of the spare transmission when I sell my own stock one after the project is complete. All told, the transmission work will have cost about $4575 when it's finished.
Stupid? Perhaps. However, this is a hobby for me, and I am thus able to chalk some of the cost up to entertainment. My physical state at this point pretty much requires me to drive a Tip or other clutchless transmission. The B5 S4 is the most entertaining car I've ever driven, and it fits my lifestyle rather well. I derive enjoyment from the modification process, and the car itself is paid for. I like the B6. It's smooth and quite refined. However, I am not drawn to it in the same manner. To me it is, for a lack of better words, a domesticated version of the B5 I already own. With the Level10 gearbox aboard, I will be equipped to go Stage III and beyond. I expect this car will serve me well for quite a while.
For those of you who suggest a Porsche, I would say, "love to!" but only as a second, less practical car.
For those of you who suggest a WRX or an Evo, I would say, "I'm 33, and they don't appeal to me."
For those of you who suggest the 2005 Lecacy, I say... "Hmmm... Intriguing, but still not enough."
For those of you who suggest an E46 M3 SMG, I say, "I considered it, but I prefer the sleeper appeal of the S4."
Old 01-09-2004, 07:48 PM
  #12
S4Per's Avatar
Default Re: Costs associated with the transmission...
All I can say is: Enjoy it! (I feel exactly the same way and hope to have the $ available to go the same route) :-)
Old 01-09-2004, 09:49 PM
  #13
New Member
a666's Avatar
Default What stall speed are you coosing? 2500RPM?
Don't go too high on the stall speed, since it will increase, to a higher RPM, once your engine produces more torque, near the stall speed.
The torque limits of the transmission are set by the weakest link, which may not be the torque converter. On a specific transismission model/make, there may be specific weak links, but the wider bands and more clutches in the clutch pack are common improvements to increase torque, without slipping.
The valve body is often modified to increase the shift pressure on the clutches and bands. It is usually setup to increase the speed of the shift. This ususally just consists and drilling a few holes larger and changing a couple of springs and/or pistons, which changes the rate of the servo filling.
The higher stall torque converter will reduce turbo lag and soften the firmer shifts of the valve body.
Keep us posted. I have done this on some American cars and may do this on my S4 TIP, in the future, since Porsche, BMW & Mercedes are too flashy and the RS6 is a little large and pricey.
Don
Old 01-09-2004, 10:25 PM
  #14
Senior Member
Skydive@AI's Avatar
Default On the advice of Level10, I am going to go 2800 RPM...
Mike, (BLK01S4), originally went with 3200 RPM and changed his mind, and sent it back for 2500 RPM. Sam at Level10 says 2800 is the sweet spot, so I'm taking his advice.
Old 01-10-2004, 08:28 AM
  #15
Craggy Old Man
Ming 2.7T's Avatar
Default Please keep us in the loop on how it goes. Appreicate you taken the plunge
and giving us the inside scoop.
Old 01-10-2004, 02:29 PM
  #16
internecine's Avatar
plus a bit more for install, right?
Old 01-10-2004, 08:39 PM
  #17
Senior Member
Skydive@AI's Avatar
Default Not really...
The trans will come out when I do the Stage III install, (with help from the LA crew), so I'll be putting the Level10 trans. in simultaneously.
p3u
17
07-25-2005 05:18 PM
matt_sonic
14
12-09-2003 12:42 PM
OldSkewS4
37
07-21-2003 09:15 AM
enpassant
06-06-2002 08:21 AM
DaleB
08-08-2000 05:06 AM
Quick Reply: Torque Converter on Tip '00 S4
