Track times
Track times
60': 1.81
1/8: 8.40 @ 84.19
1/4 13.15 @ 104.55
Mods are listed below. RS4 clutch really allows me to launch harder, definitely happy with it. How much mph are you guys typically gaining in the last 1/8? As you can see I'm only getting about 20mph, which is much less than I'd expect. Heck, my Typhoon gains 23 and it is a brick! I'm shifting into 4th at about 6100-6200 rpms, I'm wondering if I should be shifting it earlier. I think MAF's start dropping off at 6000. Do you guys slam the throttle down after each shift? On the way home I was experimenting and the turbo seems to spool faster if I quicky "ease" the throttle back down rather than slam it to the floor right away. Make sense?
Todd
'01.5 S4
DP's, Twin2 Exhaust, LW flywheel, RS4 clutch, Baileys, EFK, Giac X.
1/8: 8.40 @ 84.19
1/4 13.15 @ 104.55
Todd
'01.5 S4
I pick up about 22-23
I shift to 3rd and 4th around 6000rpm's , what your doing is optimal. I don't ease throttle in or anything like that.
I'll post my breakdown later but I do know that your 1/8th MPH is higher than mine.
you should log to see what's goin on...m
for instance on my car i noticed bigtime overboosting and throttle cut and my G/S were pegged at 200 ( that is what stock should be at).
the car ran a 13.5 at 100 mph. way under it's potential, but i've fixed my overboosting problems and soon will fix my MAF, and see what happens.
good luck sorting it out...
Ray 90 G60 Tornado Red
00 S4 Silver/onyx...some mods.
