tranny difference with rs4 s4 a6? or is it the same~
Correct. More...>
You can get an RS4 6 speed and it will swap in directly with no additional mods. It will benefit you by giving you lower rpms in 5th & 6th gear, resulting in better fuel economy & higher top end(depending on your engine).
We can get these for $4000, and are readily available AFAIK. They come in different setups, either machined to use the OEM US spec spacer, or to eliminate it altogether. Also, even the US spec 6 speeds are fairly easy to sell if they're in good working condition. Usually fetch around $2000.
KO4ed in Phoenix
10
04-28-2005 02:32 PM
/\UDI~o~phile
11
04-14-2005 09:57 AM
gimp2.7
07-07-2004 10:54 PM
huwla
9
03-18-2003 11:00 AM
