Trunk lights aren't working, is there a fuse for that??
I looked thorugh the fuse panel and no luck, the interior lights all work, the license plate light work, but the two lights in the trunk don't. Any ideas?
have you replaced the bulb? you have 2 lights in the trunk?
Right two lights, niehter one works... no on the bulb
I do have the fog light mod if that makes any difference
so you are talking about your rear fog lights.. not the interior trunk light?
or both.. trunk light and rear fog
Trunk lights don't work, the fog thing was FYI, they work
Raise the trunk all the way and shake it. Mine has a problem with the switch.
Shake the deck lid?? How do you do that?
when the trunk is open almost all the way. move it from front to back about 6 inches pretty fast.
There is a switch something like a mercury switch that turns the trunk light on when its open. Mine was taking a little while to turn the light on after the trunk was open. If I shake the trunk lid a little when its almost open, the light will come on. You are just moving the trunk along its normal path of opening.
Ok, I'll give that a shot at lunch and see what happens.
