Two specific questions
I have a bit of an issue. In my 2000 s4, up by the pop out cupholder there are three buttons two for fog lights and one for "esp" I believe which is the traction control button. I dont have the traction control button. How would I go about getting this traction control button to work?
Also on the exterior of the car by the two rear doors on the side skirt there are two little plastic protectors that have faded to a slight yellow over the years. Is there a crome metal peice to put there to match the trim around the windows?
Thanks for your help. =)
Re: 2000 S4's dont have ESP
Hm interesting. Thank you. I really like your car s4orce. I was reading your description and a tiptronic recode? What has this done for you?
All your upgrades are making me drool a bit. I am looking to enhance my car along the same lines as yours. Would you consider a boost controller for your car?
You talking about the x-pel or clear-bra type stuff? That stuff can be purchased in sheet form and
then you could remove the existing pieces and cut new ones. The stuff should come off if you heat it up with a hair dryer, but you might want to STFA first to see if someone has done this before. I have this protection on my headlights and fogs, but the stuff on the rocker valence is fine on my car. The red will hide some of the yellowness though.
target39
12-16-2018 06:11 AM
kidfrostnj
9
08-08-2003 11:13 AM
