Urgent pls: Need pics/info on oil lines to passanger's turbo
I need to know where they connect, which one is return and which one brings the oil, etc.
Where is the pressure coming from?
(Is there a specific pump for each turbo, etc.?)
Thanks so very much in advance.
and the thick braided line you see coming down from the turbo is the return line (oil to pan)
<center><img src="http://pictureposter.audiworld.com/47312/engdrop12.jpg"></center><p>
Re: it's the wrapped up line
Thanks for the reply.
Few more questions please:
The wrapped-up line is the 'incoming' right?
Is there an easier to get to spot where they come out of the engine?
How much work is needed to get to them?
(Which parts/bits need to be dissasembled?)
Thanks again.
Thanks again.
that is the feed line , you can't really get to the that connection while the engine is in..
i tried to put some insulation around that line and man..there no space there at all. the line coonects in the back of the engne ..i don't have a pic of that ..look closelly and you maight spot it back there.
you may get to that if the rear of the subframe is lowered a good amount
the second picture is taken when the subframe was removed and the engine was lowered ~12 inches.. that was to allow the turbo replacement without removing the engine .. simpply can chime on that (iirc that was his work ).
rakta *chchchanges
03-26-2009 03:34 PM
Arcteryx::Stock Rods
09-17-2006 02:03 PM
DJ Springer
Quattro: Turbo / Ur / Sport
08-06-2002 09:13 AM
