using vag and reading block 032 it reads...
idle at positive 1.2 ( average ) and partial reads -16.4 on both banks. How rich is this ? is this within the range of the ecu to correct ? what is ideal range for 032.
Also have misfire at idle in cylinder 5, is running + 1.2 at idle possibly causing this ? Also I am running 93 non oxy octane. |
way rich IMO... what's your setup?
stage 3+, total rs4 except heads are 2.8 Bosch MAF
did about 3-4 pulls in 3rd gear, car was a little lean up top so we added fuel, like 110%
Do a search for lemmi tweaks with docslow and mike2ks4@peb.
Please define lean: Logs of 02's and 003 and/or wideband would really help.
+1.2 idle wouldn't cause any problems, that's perfectly fine. You might have a dirty or misaimed injector... or something ignition related, like a coilpack.
Something's not right, Jim. Get the car checked out and/or run some logs.
I don't think our cars can adapt that much, just crazy rich.
Nah, get the car checked out before touching Lemmiwinks.
Something doesn't seem right.
I'd get the car checked out by a mechanic before running a bunch of logs......
Call me a wusspod if you must, but that's just my 2 cents.
I guess. Could be a MAF, that's why I asked for the logs...
I was assuming he logged something to get these results. I just want the data to confirm.
MAF reading too high causing a rich condition? I'd understand if he was lean......
