vag-noob alert ... Block 115 - is this a healthy log?
<center><img src="http://pictureposter.audiworld.com/41342/block_115.1.jpg"></center><p>I haven't corrected data for atmospheric pressure. If I subtract 1000 from the data - my boost would be only be .6 bar max (as per chart)... that can't be right - can it?!
Also... initial lag seems more apparent than I would've expected - is this 'normal' (K03's)
obtw... this was a 3rd gear pull - 1st attempt.
Stock mode? Looks fine. (more)
If you have multiple slots on your ECU, do you know what order the programs are in? Every time you remove the ECU or disconnect (or drain) your battery, it goes back to the first slot. Do you have stock program in first slot and have reverted to that?
Stock software I assume. If so, looks perfectly fine.
That is no lag at all IMO and atmospheric pressure is not always 1,000 mbar. You can see what atmospheric pressure is by looking at actual boost while sitting at idle.
There is no purpose to have a chip if it always in stock mode. Likely has EMCS have you tried to..
change modes from cruise control stick? Can get instructions from APR's web site.
Bruce
Bruce
