Weekend Races -- My MTM Stage III S4 vs My 800hp T66 Supra vs 400 hp RX7
Well I decided to see how my new MTM Stage 3 S4 would hold up against my 800 hp T66 Supra. The Supra has a fully built engine with race cams and a huge 850 cc fuel system. I decided to drive my S4 and had my buddy who brought his 400 hp RX7 over drive the Supra.
We decided to race from 5mph to 100mph so not to put too much tear on the clutches. Well no suprise but the Supra toasted the S4 but it was only by about 6 cars at 100mph when the Supra slowed. The S4 was only about 2-3 cars back until I hit 3rd gear and could feel the S4 begin to wheeze over 4.5k rpms. The Supra was also having serious traction problems in 1-2nd gear so it may have been worse. Anyways the next race was me driving the Supra and my friend driving his RX7...again from 5mph I instantly had 2 cars on the RX7 then held about 3-4 all the way to 100mph and was still moving away at a good rate. The RX7 was running 12 psi while the Supra was running 18 psi. The RX7 has a ported rotor and has beaten 405hp Z06s by ~1 car length on 2 occasions. It dynoed 330 rwhp @ 12psi at 2750 lbs. So you guessed it the next race was me driving the S4 and my buddy driving his RX7. We both punched it at 5 mph and I held 1/2 car length all the way to 3rd gear and by the top of 3rd the RX7 had 2 car lengths on me...not that bad and was slowly pulling away. I was certaintly happy given the car still has stock ICs and stock turbo's. I also destroyed a Camero SS and Mustang 4.6 V8 this weekend in the S4 by about 4-5 and 7-8 cars and believe it should run dead even with a 385 hp Z06. The S4 is definitely a sleeper! Isaac '01 MTM Stage 3 S4 '94 T66 Toyota Supra |
sweet! except I doubt the S will run dead even with the Z06
Z06 has 405hp not 385. That's awesome that the S4 hangs that close to the supra though. Especially from a 5mph roll. The S4 sucks from a 5mph roll. you need to take advantage of the quattro launch.
Nice write up. What does stage 3 involve from MTM? Please list your mods. Thanks.
pre 2001 models have 385
t66 on 18psi? 800hp? ermm no.
still don't think it'd run dead even but I didn't know that, thanks :-) learn something new everyday
Re: sweet! except I doubt the S will run dead even with the Z06
the pre 2002 Zo6 has 385 hp/ 385 lb/ft. whereas the '02 Z06 has 405hp.
My Supra ran 10.6@135mph at 700rwhp on 28 psi and puts down 599 rwhp at 20 psi. My S4 has the 18 psi MTM chip, down pipes, high flow cats, cat back, Stop tech brake package, upgraded plugs, 5 bar fuel pressure regulator, and a K&N filter. I have no doubt this car is a high 12 sec car and the 385 Z06s run 12.7s. Also my buddies RX ran a 12.1@118 Isaac |
Re: t66 on 18psi? 800hp? ermm no.
Here are the Supra Specs:
599 rwhp @ 20 psi 579 rwhp @ 20 psi SAE = 579/.85 = 680 Crank HP 707 rwhp @ 28 psi SAE = 707/.85 = 830 Crank HP Only losses so far are to my friends C5 LPE TT which runs 10.1s@136 with 626 rwhp and 728 rwtq. Wheels: 18 inch Yokohama AVS wheels 9" fronts and 9.5" rears Bridgestone S03 pole positions Suspension: KYB-AGX 4 way adjustable shocks Greddy Grex springs cusco rear and front strut bar Turbo/Other: T66 .81A/R, TSo4 housing exhaust side is .71 Greddy Type C wastegate holds up to 1000 rwhp Greddy manifold Greddy Type R BOV Greddy 4 row FMIC Custom 4" ram Air system Fuel: 850 cc injectors, new fuel rail a HUGE single fuel pump capable of 1000 rwhp SP fuel system Engine (new short block components as of 10/05/01, also valves reseated): JE Pistons .020 overbore - resleved Crower Rods HKS 264 cams AEM cam gears new head gasket Electronics: HKS EVC-EZ HKS VPC Blitz turbo timer Greddy BCC Apex S-AFC Gauges: Greddy EGT white face gauge peak hold Blitz Boost gauge Exhaust: Greddy SP Exhaust Custom DP Clutch: RPS Stage 3 sprung hub clutch Mueller lightened flywheel (13 lbs vs. stock 37 lbs) Misc: Indliglo white face gauges Aluminum razo shift knob Carbon fiber pedals reflective tint hyper white bulbs Body Kit/appearance: Veilside rear skirts Stillen polyurethane front facia white 97 turn signals |
sorry, my bad about the 385 i didn't know, but you have to remember that the corvette weighs over 500lbs less than the S4, and your car probably has about 350hp. I dunno, it would probably be a pretty good race and I would love to see you kick one's ass. So if you ever do, make sure you get it on video so I can see it :-)
Peace! |
yea, I'm with ya :) The 385 HP versions still pull low 12s easy.
