What is the correct 60 lbs injectors’ orientation?
I used stock orientation, Pass side the injector connecter is facing the radiator and the Driver side the connector is facing the firewall.
<o></o> For all of those who are using 60lbs injectors on their car what is the injector orientation that you used to install the injector? Where is the injector connecter facing for each side? I have misfires at idle! http://www.ctsturbo.com/images/products/inj60hs.jpg |
what sort of tuning?
I am using VAST for my tuner, but what does it matter?
Some tuners injectors are orientation dependent. Ask Vast. My ASP 60#'s are not orientation dependent.
Frankly, it is better to contact your tuner and tell them you have misfire issues and get their read on it. Bruce still old and crabby |
will do.
i know "Tuners" claim that but .. sure sounds like Voodoo magic
if the injectors are properly sitting in - and if they are atomizing the fuel properly.. i dont think any of these injectors are directional spray patterned. Possibly lining up the triangle with a religious "belief" (if your injectors have 3 holes on them... but besides that ..
I don't think it does much.
Originally Posted by MySTG3S4
(Post 23799770)
