What Ohm reading for S4 crank sensor ?
My 59 degree is jerking around (the Value is changing)
Brady tested the crank sensor to get like 900 oms ?
I dont have the Bentley to check it.
I hope it's not the ring on my CM flywheel that broke loose.
BTW mike could you send me one of your dynograph just for comparison ?
Thanks in advance
Dom.
Thanks in advance
Dom.
put 1-2 washers on the crank sensor to space it out. You need to about 2mm space on the
crank sensor and the trans housing. Just 2 little washers 1st,2nd sensor,3rd install.
try it. I had the same issue.
beemerfanatic
09-11-2009 10:11 AM
