What size (allen) hex head socket to remove axle?
17mm
no size will fit
(properly) because it is not an allen/hex type. They are triple-squares / 12-point.
I believe it is a 10mm for the B5S4 (and 8mm for the B5A4) <img src="http://ctny.audiworld.com/mark/s4/clutch/4_remove/dsc01970.jpg"> |
ohhhhh, *that* bolt ;-)
you're referring to the bolts that hold the inner cv to the tranny. They're 10mm triple squares
NAPA, Autozone and a few other places carry them
Dave |
which need to be removed to remove those "axles"....
EDIT: I had thought I had removed my half shafts entirely and was thinking I didn't remove that big bolt - but I only removed the inner CV connections.
Bolt holding axle to hub?
Thanks for all the replies. I guess I wasn't clear enough but thanks.
which axle?
FYI, the center shaft uses standard allens...
<img src="http://ctny.audiworld.com/mark/s4/clutch/4_remove/dsc01965.jpg">
huh? you're losing me. The front axle DOES have a 17mm driveshaft bolt that secures the splines of
the driveshaft the the hub / spindle assembly. The other half of the axle is connected to the transmission by the 10mm triple squares.
Dave |
