what's the maximum front suspension travel?
I would like to disconnect the front shock and raise the front wheel to see exactly where the tires rub before/after rolling the fenders.
The problem is, I'm not sure what the limit of upward travel is with the ohlins & 650lb/in front springs. I had very slight rubbing with the front end lowered to something like 25-25.25". I'll have to STFA for my own info
I also need to get a very good idea of how much clearance I have to reduce negative camber using K-mac bushings. The ET=30 BBS wheels stick out pretty far with stock (lowered) camber, so I'm thinking I should verify there's room for less camber before spending $275 on K-macs.
I guess I could roll the fenders as much as possible, use K-mac bushings to set camber to approx -1 deg, and keep raising the ride height from 25 inches until rubbing goes away.
I'm just trying to get a game plan. thanks
Ray Khan
07-25-2006 05:41 AM
Anyone know what's the most aggressive wheel/tire fitment that can be put on a standard Type44, if..
Type44Q
06-30-2003 09:47 AM
