What's the strongest clutch a fidanza flywheel can be used on?
Thanks, that's what i'm asking for. Because Clutchmasters Stage 4 can't be used with fidanza so I
was wondering what other options there are that can use fidanza? I will search into those South Bend clutches. You have any experience with that set up?
It is a very durable set up, probably a little rigid for street use... however
if you are putting down enough torque to require such a set up, then admittedly you will not find a more quality option. The RS4 PP combined with the FE series dual faced Feramic compound disc make for a supreme heavy duty clutch.
I have a CM stage 4, 8 puck
<center><img src="http://www.valitalo.org/images/engine_tune/CM_stage4_vs_OEM.jpg"></center><p>I have read from here that the stage 4 doesn't work with the Fidanza, but at least the 8 puck version works.
There is even more space to the flywheel bolts than in original clutch disk.
Gjaime
08-20-2006 08:28 PM
Warning3
12-23-2004 07:36 PM
Phishie [K04]
09-26-2002 06:38 PM
