When i'm getting on the gas pretty hard.......
I feel my car is loose coming around some slight turns. How can i help this feeling go away. I am running Bilstein shocks with MTM springs. I was told by Audi service that my tie rods were in need of replacement, if that makes any difference. But Audi won't replace these under warranty, as they are a wear & tear item. SUCKS
Re: stiffer swaybar will help you a lot.
Are these the ones that go on the bottom of the car or on top of the engine? I haven't seen one that goes on top that doesn't require taking out some of the engine trim. And i really don't want the one on top if i have to remove trim.
Huh... thicker swaybars *add* or *take away* traction?
I was under the impression that increasing the stiffness of a swaybar actually takes away traction from that particular end of the vehicle where the increase is made...
Everyone complains that the chassis has a tendency to PUSH - hence folks sometimes remove the front swaybar entirely, thicken up the rear, and even go with a stiffer spring setup on the rear of the car than what they run up front. Is this correct?
If you're under the original factory warranty, tie rods are most certainly included.
Literally the only thing that is not included in the original warranty is tires. Everything else, including brakes, is included.
