Will 17" AT Rivas with 235/45-17Pole-3 fit S4Avant WITH Intrax/koni susp?
I was told by TireRack that the 17x8 Rivas will fit with the Intrax/Koni lowered stance. I'm not too sure with that answer and would like to hear from someone running this set-up before SPP ships the Intax/Konis next week Should I get coilovers to be sure..HELP.
DennisD '01 S4Avant 6-pd, GIAC, Neuspeed sway bar,exhaust. |
They'll fit, but you may have a little rubbing...
I'm running that set up on my S sedan with out rubbing issues. However I've got 225/45/17 Pilots
<img src="http://pictureposter.audiworld.com/178/low_front_quarter_mall.jpg">
Too late to stop the wheel/tires-would coilovers cure?rolling fenders?
Not sure whatis done with "rolled fenders" is it removing the plastic protectors? Isn't the front arm the site of rubbing?
Have you had a full load in your S4? Maybe the Avant is about 1/2" heigher.. DennisD |
Rolling fenders would work. No, you're actually "bending" the sheet metal to accomodate wider tires
Do I need to do this or should I just cancell the Intrax/koni
