will the giac x-chip h box work on the m box? part number...
Old 04-15-2005, 01:27 PM
New Member
mikeofgte's Avatar
Default will the giac x-chip h box work on the m box? part number...
i have a 2001.5 mbox 6 speed, i want to purchase a chip that is made for the h-box, the part number is 774j08x.07A
does anybody know if this chip will work on my m-box?
ive tried to call awe but no answer..summertime here they must be busy folks.
thanks
Old 04-15-2005, 01:47 PM
Member
jprice@CPS's Avatar
Whatever you do, make sure it comes WITH the encryption board.
Old 04-15-2005, 02:55 PM
villainS4's Avatar
No, M box and T box are interchangeable, AFAIK those are the only ones.
Old 04-15-2005, 03:00 PM
New Member
mikeofgte's Avatar
Default sorry i meant, will the chip work on the m box..not the h-ecu, just the h chip.
thanks
Old 04-15-2005, 03:03 PM
Member
jprice@CPS's Avatar
Default I knew what you meant.. was just giving you a warning as a chip buyer (more)
Many people try and sell JUST the chip. If you don't already have a GIAC encryption board, the chip will be worthless do you. When people sell a used chip, it should be sold WITH the encryption board. You cannot just get a GIAC chip soldered right onto the ECU.. it won't work, you need to solder the encryption board onto your ECU, then put the chip on that.
You may already know this.. just cautioning as many have been burned by this in the past.
Old 04-15-2005, 03:15 PM
Guest
neilm's Avatar
Default I run a H box on my M box car. 2001 Avant
You do have to do some recoding of the instrument cluster through VAG-COM. I can't remember the settings, so please someone post the procedure.
Old 04-15-2005, 03:26 PM
Member
jprice@CPS's Avatar
instrument, adaptation channel 60.. if it's 1025, make it 0, if it's 0 make it 1025
Old 04-15-2005, 03:43 PM
Senior Member
JBear::FATS's Avatar
Default H and M play fine and even A if you switch to the Hitachi MAF.. Just need to recode the
Instrument Cluster ..
Old 04-15-2005, 06:04 PM
MDIAU's Avatar
Default hey i'm the guy selling the giac chip and yes it does have the encrytion board.
everything taken off @ Induktion =)
Old 04-15-2005, 06:05 PM
MDIAU's Avatar
2nd
DARKiGOD
03-12-2006 10:14 PM
Silv3rMoto
12-26-2004 05:31 PM
lobo90210ca
Canadian Discussion
08-19-2004 01:21 PM
fasTTcar
05-07-2004 06:14 PM
floppy trout
12-18-2001 07:22 AM
Quick Reply: will the giac x-chip h box work on the m box? part number...
