Wind Noise
Wind Noise
I get serious wind noise leaking in where the front doors meet the B-pillar at the top corner. This happens at 120 MPH+. does everyone experience this? Any tips on re-aligning the door?
thanks
thanks
Known Problem... There's a way to fix it.
There is a web page about that left mirror noise problem at high speed. I'll try again to find it and post it here.
You have also this help file HERE on AudiWorld. Go in "Tech" section, click on "Misc. Topics" and search for the A4 mod named "Fixing wind noise problems".
Basically, you must go at Home-Depot and buy plastic-rubber tubing (like a long straw, small diameter) that you push and squeeze inside the space between the door and the mirror (where the mirror connects).
you can align the door, AND the window portion
If you take the interior portion off the door, there are adjustment points for the window frame both at the hinge side, and the latch side of the door. (Allen bolts if I remember correctly)
These are adjustable, as is the latch on the B-pillar itself (though you need a tool called a "tripple square")
It takes a while to get right, patients patients patients....
Rian
Rian
bigmacunion
10-26-2004 06:17 PM
Metronet
05-23-2003 12:12 PM
ILLusive
04-22-2002 09:32 PM
