Windows squeak? Dealer only way to fix it?
Old 07-31-2003, 09:47 AM
Bruck's Avatar
Default Windows squeak? Dealer only way to fix it?
I have been noticing my window squeak is back (the moment I put down my windows, they squeak for like half a second and then they go down quietly the rest of the way. I was told that I could have the dealer remove my door panels and fix this problem.
However I am about to get my car tinted all around, I am wondering if I should get the dealer to fix this problem FIRST so that they don't blame it on my tints.
OR if there is another solution that I can purchase myself. I was told there is some type of non film lubricant but I went to a few auto parts stores and had no luck.
Suggestions?
Old 07-31-2003, 09:48 AM
Vtec_Killer's Avatar
Default Mine did that, but went away when I cleaned the exterior
of them every week.
Old 07-31-2003, 09:53 AM
New Member
itr0045's Avatar
Default Re: Mine did that, but went away when I cleaned the exterior
If you put a little baby powder on the window and roll it up and down a few times, the squeek will go away. You just have to clean up a little mess after application.
Old 07-31-2003, 09:58 AM
Steve Trac, Sec 303's Avatar
common, especially in warmer temps. keep everything clean and live with it.
Old 07-31-2003, 10:02 AM
Elder Member
No More B5 S4's Avatar
Thanks for the tip.
Old 07-31-2003, 10:29 AM
Bruck's Avatar
Steve, did you see my response to your post in the B6 forum to me?
Bruck's Avatar
Gonna try this today
Old 07-31-2003, 10:45 AM
Default just now:
When they first came out, Zev *flew* to his customers to install it. You'd have to contact them to arrange an install. Yeah DVD is much better than CD. In the B5 unit though, you *could* play a music CD if you removed the data CD.
I'm sure a B6 S4 Nav unit will fit in a B6 A4 though!!
Old 07-31-2003, 10:46 AM
VerrÜckt's Avatar
Silicone Spray in window tracks works very well.
Old 07-31-2003, 11:02 AM
AudiWorld Expert
mpwolf's Avatar
Please don't spray silicone around a car.
Quick Reply: Windows squeak? Dealer only way to fix it?
