Would going to a colder plug solve missfires?
try what he said...if you continue to experience the same issue
check all plugs (if you havent changed them in the last 40K miles, they do need to be replaced). If that doesnt solve your problem, talk to Bruck. I think he experienced the same issue and might be able to give you more info.
well, if you've changed plugs, amplifiers, wires, and coil-packs -- seems to me that it's most
likely a head problem. might do a leakdown test if the misfires are numerous enough. How many are you logging in a minute? Are they only at idle?
Re: well, if you've changed plugs, amplifiers, wires, and coil-packs -- seems to me that it's most
Yes they are only at idle. I will try to get the leak down test done
eigenvector
06-29-2006 06:05 AM
Marcus Frost
11-01-2005 06:20 PM
rr25
Audi Original "S" Cars
04-15-2005 10:28 AM
