WTF? A hum that gets louder and louder as I go faster...
Old 04-23-2004, 04:43 AM
daves4's Avatar
Default WTF? A hum that gets louder and louder as I go faster...
starts around 30mph, i hear the OTHER hum from the drivetrain between 40-45mph (that one goes away), but this one keeps building.
Sounds like its coming from the rear of the car. Do I perhaps need a 'lube job'?
Old 04-23-2004, 04:45 AM
lemieux@curbside's Avatar
Default it's probably your rear diff...
u may need to have someone look at it..
first check level of fluid ..but usually it make noise when the ring and pinion are worn out..
see if it changes note under load..
Old 04-23-2004, 04:51 AM
daves4's Avatar
Default Wow! Great answer! Let me ask you...
The noise seems to momentarily go away when I turn to the left (ie going 50-60mph and highway banks left), but not to the right. Does this make sense?
Old 04-23-2004, 04:58 AM
Cooper993's Avatar
That may be a rear wheel bearing
Old 04-23-2004, 05:10 AM
Junior Member
slvrbullit's Avatar
sounds like a wheel bearing needs to be replaced
Old 04-23-2004, 05:30 AM
Default yup...that maight be .
if the noise is more pronunced when turning that side (so more load on that wheel ) it may be the wheel bearing, if the noise tone changes when accelerating straight line (the diff under load) may be the diff.. that how u can verify and get an ideea.
but if it does it when load is on one side ..than most likely is the wheel bearing.
try all this and see what really makes a difference.
let us know how it goes..
Old 04-23-2004, 06:34 AM
Aldonis's Avatar
Wheel bearing - I'd put money on it. Just had the same thing and had it replaced
Old 04-23-2004, 06:47 AM
daves4's Avatar
OK...If its this, then how much to have to fixed?
Old 04-23-2004, 07:06 AM
New Member
beachwood's Avatar
Default Re: OK...If its this, then how much to have to fixed?
I just paid $250 - probably too much, but....
Old 04-23-2004, 07:15 AM
daves4's Avatar
At a dealership? Because the one by me said, like $325!
Quick Reply: WTF? A hum that gets louder and louder as I go faster...
