Yet another AC question - kinda hard to explain
Ok so events were:
1) K04 install (battery disconnected for extended period of time)
2) AC stopped working
3) Recharged through low service line
4) voltage checks out
5) changed ECU H-box to M-box and recoded
6) no VAG codes at all in the system - 100% clean (knock on plastic keyboard)
Question is, there a chance the HVAC controller lost programming causing the car to forget it has AC?
Friend of mine said he saw it happen on a VW before.
it doesnt turn on at all, or it wont cool? the installer might have...
forgot to plug in a connection when putting back everything, its been done before
it just blows warm air, but I do get air circulation
my friend climbed under and said it appeared everything was plugged in and he had voltage going to the AC compressor so I believe that means its plugged in as well
I just want to be 100% sure before spending $500 in labour to pull the bumper etc as you can imagine
no leaks in the system
I recently had to refill freon, but you said you already did that..hmm but read this.
<ul><li><a href="https://forums.audiworld.com/s4/msgs/2819245.phtml">https://forums.audiworld.com/s4/msgs/2819245.phtml</a</li></ul>
hehe - ya I just checked from this picture - gonna check at the dealer tommorow about the HVAC contr
<center><img src="http://pictureposter.audiworld.com/33171/dscn1729.jpg"></center><p>
ModifiedA4
11-20-2007 11:46 AM
freshs4ny
04-23-2007 11:37 AM
