2013 C7 S6 Brake Caliper Decal
#11
There's not that much heat on the calipers unless you're tracking the car. Touch them (or use a thermometer) after your normal drive. Regular paint and vinyl should be good for 275*-300*F.
Touching calipers is also a good way to see if one of your pads is dragging. Touch a wheel to check if the bearing is going. Both on the same axle should be about the same.
#13
#14
This is an old post. Can anyone point me to a quality set? It just looks like a mess out on eBay. Per another post, I might repaint them, but if there are truly matching decals I can replace over the existing ones, I might try that first since painting is a big deal requiring removal. It would be great if there was an Audi part you could just pick up!
kneehurts
07-29-2008 01:59 AM
