S6 (C7 Platform) Discussion Discussion forum for the C7 Audi S6 produced from 2012 - 2017
Headlight Fogging - 2013 S6?
Old 09-08-2013, 06:50 PM
GermanGarage's Avatar
Default Headlight Fogging - 2013 S6?
After my Audi S6 returned from it's new front S6 black optic replacement grill operation, I noticed that the drivers headlight cluster fogs on the inside of the lense during a car wash. This has never happened in the past. The condensation covered the entire inside of the lense.
Is this normal for these lights -- given I have never noticed this before...? Or did they break a seal and I need to get it serviced?
Thoughts?
Old 09-08-2013, 07:03 PM
Harsany's Avatar
Not normal. Needs to be fixed.
Old 09-08-2013, 07:04 PM
snagitseven's Avatar
This is not an uncommon issue in several models for some time. Audi has issued TSBs. This one is for the 2012 A6 but may apply to 2013s and the S6:
http://www.automd.com/tsb/bulletin_b341964/
Old 09-08-2013, 07:22 PM
Argh. I am convinced this happened during install.
Oh well, will make an appointment.
Old 09-08-2013, 07:27 PM
///M Traitor's Avatar
I've seen some condensation on the inside of my headlight as well, but I read that it was normal as long as it goes away with the headlights on. It made sense to me because I figured the LED headlights are not sealed with the forced air cooling fams. Of course it is possible that a heat-sink is located in an unsealed portion and the rest is sealed, however I was hoping to avoid a trip to the dealer and it only happened once or twice...
Old 09-09-2013, 04:07 AM
subterFUSE's Avatar
Do the LED lights get hot?
Old 09-09-2013, 04:19 AM
Yes. There is a fan integrated in each LED headlight housing to mitigate the heat.
Old 09-09-2013, 05:42 AM
High-power LEDs need to be kept cool to protect the semiconducting medium from damage. Whereas an incandescent or HID can tolerate high heat.
LEDs do produce significantly less heat, however the heat that is produced must be drawn away from the LEDs themselves.
Old 09-10-2013, 05:28 PM
keithl's Avatar
So then fogged headlights for Full LED is normal? I noticed on my brand new A6 on the first wash when the cold water hit the headlights they fogged inside a little.
Old 09-10-2013, 06:27 PM
Thats when my lights fogged. Is this normal and I just didn't notice it earlier?
Quick Reply: Headlight Fogging - 2013 S6?
