225/45/19 snow tire size? thoughts?
#11
I have owned A6s and now an S6 since 2001 and live in NH. I have never installed a snow tire, but have used all weather tires. I have never had a problem with snow or ice, the car is fantastic in the winter. The only problem is low ground clearance, so independent of the tire the car does not do well in snow greater than 6"
Try them and you won't go back.
#12
Have you ever tried a dedicated snow tire? If not, you should. If you think the car is good on all-seasons, you should see it on snow tires! Braking is easliy 30% better. I've tried both of my Audis both ways and the snow tires are far away better than even new all seasons.
In addition to the fact that it drives great with all weather, the following are my reasons for not wanting snow tires:
1. no need for off season storage
2. no need for additional wheels or twice yearly mounting of tires
3. since I don't run the S6 on a track, there is no noticeable difference between summer tires and all weather
4 If you add up your costs, you're spending money that you could use to by your next S6 sooner.
#13
Yes I grew up in Minnesota and have driven 100s of thousands of miles on snow tires. In addition I raced cars on ice, quite successfully. I have a F150 4 wheel drive and the Audi with all weather is better in everything but deep snow.
#14
I ask myself the same question as this 72 yr old carries 4 Michelin Arctic Alpins on Audi 19 wheels to the tire shop to have their balance checked and have them mounted. Then we get the first ice and maybe light snow and I remember why I did it. Furthermore, even though the winter tires (not really snow tires) aren't bad re handling, I remember the handling of the P Zero summer tires on the first spring days that I carve some hilly two-lane balcktops at twice the speed limit. Its not about going, its about stopping. All cars become all-wheel-drive when you hit the brakes and lock the wheels on ice. Look at the numbers from the tests at Tire Rack and you'll see that AS tires are a compromise, especially in winter. If you buy a performance car it should perform and tires are the key component in that case. As to anybody who doesn't notice the difference between good summer tires and the best AW/AS tires, I say that you're not driving fast enough. BTW, I use 245/45/19 winter tires because I am mostly concerned with traction after the roads are cleared. If I need clearance with heavy snow I take the SUV. I just put Michelin Pilot Sport AS tires on my Corvette. These are run-flats and they ride better than the Goodyears but there is a clear loss of performance noticeable to a guy who drove SCCA 25 years ago.
#15
#16
i think you misunderstood me, i didn't say that i wanted "to get by", i was just agreeing that all-seasons will work fine throughout the year for most people. i've always had dedicated snows and summers on my audis - my only gripe with separates is about an hour after i've changed over wheels on both cars in an afternoon, my back is screaming at me. as for driving fast enough to appreciate summer tires, of course i do, just saying in winter i'm not traveling as much and most of my driving is around town shuffling kids to whatever practices they have, and i'm not exactly out in the country so there's not a lot of roads for me to "carve" up......anyway, if i'm going thru the effort of separates, i'm going to get the most capable tires i can (within $$ reason), so you've actually answered my question regarding 245/45/19 snows - sounds like you run them with no issue? i can't imagine there would be any negatives aside from speedo errors, i had michelin x-ice's on the C6, they were good but the traction control nannies on the car were always kicking in, very strange and disconcerting at times, i much preferred my 6 sp. A6 2.7 in the snow (i think i ran dunlop D3 or 3D snows, they were great), it was a beast with snows, i'll be curious what the C7 is like. so it sounds like i'll probably get the hakka's in 245/45 (i've found them for $875 delivered). i wish tirerack had a wheel i liked (at least reasonably priced) as i'd prefer to just get wheels and tires mounted there (as i did for the S4) instead of hauling them all to a shop to be mounted. i found a set of rotor wheels at usarim for $700 set, and they claim they fit the S6 without issue so i'm leaning towards them, there are probably cheaper ones on ebay but i'd hate to get them and find they don't clear the calipers.
#17
#18
The Hakkas or Michelin X-ice are more aggressive than the Arctic Alpins so they trade more toward snow/ice traction rather than handling. Thats a great price for Hakkas. I am on my second set of Arctic Alpins and just checked their size - they are 255/40-19. The bill for the first set states 245/45-19. I would check the radius of each of the actual tire you will buy vs stock summer tire and maybe compare to that size in Arctic Aplpin 4? I had no issues but the radius differs slightly for different brands.
#19
Since it doesn't snow all that often in the Seattle metro area and potholes are mostly a rarity, my "winter" tires are the Michelin Pilot Sport A/S 3+ on the stock 20" wheels. My main concern is water displacement and wet traction, which is pretty awesome for a performance tire, so for those in a similar situation I give them a solid recommendation. I have a set of Pilot Super Sports on aftermarket wheels that I swap out in early summer and late fall. It's not too much of a pain, since I can usually get it done at Costco on shopping run, but does require taking 2 vehicles.
#20
