Does engine shut off when low on gas when stopped?
Mileage guessometer said I still had 10 miles of range left. I pulled off the road to finish a phone call and put car in Park. Level surface. 5 or 10 seconds later the engine shut off. Restarted and continued home. Put car in Park again (level surface) and engine shut off a couple seconds later again. Filled tank later on and car is totally fine. Is this something Audi does to conserve fuel when low?
Originally Posted by Prachatice
(Post 25152887)
https://cimg9.ibsrv.net/gimg/www.aud...ff6e0cc3b3.jpg |
You can turn this feature on/off.
More on the auto start-stop feature: https://s7d9.scene7.com/e2/Audiusast...288_Mobile.mp4 |
Sorry, I have a 16 S6. As far as I know, it doesn't have a start stop switch.
(Post 25152939)
The mileage counter is just an estimation, especially that low. You should NEVER let it get that low man. Not worth the risk of getting stranded, and maybe damaging something. Maybe S/S kicks in when it's that low; who knows. Or the computer just senses misfirings due to fuel pump sucking some air and shuts engine down to protect it. At any rate, just don't ever let it get that low and it shouldn't happen again:D.
It’s on, unless you manually shut it off. The switch pictured above glows red when it’s off. Since you didn’t know it was even there, can you be sure it was off? You were in Park, correct? |
Originally Posted by Eli McCraig
(Post 25153060)
You actually need to activate the switch to turn it off, the default is start-stop on.
Unless you reversed the switch (lilke many of us did), if the light is OFF, start/stop is ON. Pretty annoying light, so if it wasn't on before, that means your start/stop system was active. If your engine turned off with the system off (red light glowing), then you were running out of fuel. With just 10 of range, you were literally running on fumes.
