Hartmann Wheels
I put snow tires on my stock 19" rims this winter. So I'm thinking of ordering a set of Hartmann wheels to put the Pirellis that came with the car on.
Any reason I shouldn't order a set from Achtuning? Any discounts or coupon codes available? looking at HTT-256-GA:M 19" ET38 http://hartmannwheels.com/content/ph...AM_Wheel_A.jpg |
I bought a set of Hartmann wheels for my RS7 for winter and they are excellent. I got them through Achtuning and they were very knowledgeable and great to work with.
Achtuning technically is Hartmann, if you're looking to those wheels that would be the place to do it.
I like that style. Just wish they came in 20".
Originally Posted by jascooper
(Post 24562084)
Any reason I shouldn't order a set from Achtuning? Any discounts or coupon codes available? looking at HTT-256-GA:M 19" ET38 http://hartmannwheels.com/content/ph...AM_Wheel_A.jpg I subsequently purchased a new rim to replace the damaged one and they gave me a significant discount. I guess this happens a lot and they don't try and take advantage of the situation and charge full price. As noted, these are still the softer cast alloys and not forged alloy wheels, so be careful going over those road craters! |
(Post 24562084)
Originally Posted by Vijay
(Post 24562308)
Not all 19" wheels will clear the massive S6 front calipers, so you will want to confirm that these do. If I am not mistaken, this style also comes in 20x9 ET40mm which will fit nicely. Although that also means you will need 20" tires.
Placed the order. Thanks for the responses.
Not my first choice, but I really didn't want to buy new tires since the OEMs only have a few thousand miles on them. When they wear out I'll probably look into a nice set of 20" wheels and tires. Those huge brakes really put a damper on wheel selection. |
(Post 24562478)
(Post 24562645)
According to Hartmann's website, the 19" wheels require spoke balancing. This means that there isn't even space between the calipers and the wheels for wheel weights. Personally, I wouldn't do it. If even a small rock or piece of tar got stuck in there, it could become problematic.
As for the spoke balancing I have not had any issues. And I had the car on the track with no problems either. |
