Go Back  AudiWorld Forums > Audi Models > Audi A6 / S6 / RS 6 > S6 (C7 Platform) Discussion
Reload this Page >
Multiple Faults, Dealer can't replicate
S6 (C7 Platform) Discussion Discussion forum for the C7 Audi S6 produced from 2012 - Present
Old 07-11-2019, 02:19 PM
Default Multiple Faults, Dealer can't replicate
Hey everyone, came here from another forum and hoping someone can point me in the right direction, or rather help me point he dealer in the right direction.
Little background first, I purchased my 2014 S6 in March of this year from an Audi dealership about 300 miles away. A week later I received the following faults:
- TPMS, Tire Pressure System Fault
- Braking Guard Fault
- Air Suspension Fault
- Sport Differential Fault
- Automatic Cruise Control Fault
-Along with a Map sensor check engine light.
I took it to the nearest Audi dealership and they could not replicate the faults, they did see the check engine light, but also I found out my car was tuned. I purchased the car from an Audi dealership and they did not disclose this to me, or tell me the car was already flagged as TD1. They also sold me an aftermarket warranty.
They reflashed the car to stock on my dime, and found a coolant leak they fixed.
I took the car back and drove it, seemed fine until about 500 miles later when all the faults showed back up. At this time I had purchased Vagcom and read the faults, and was able to clear them. Car was fine again, until 500ish miles later. Same story. I clear them about 2 more times and had enough after I also see a motor mount fault. I tested the motor mount in VCDS and sure enough one of them is bad.
Dealer replaces motor mount, but again can't see the other faults. Motor mount is fixed so I take the car back last Tuesday. Last Sunday the faults all show up again. Monday morning I take the car back to the dealership, on the way, the faults show up. They read the car with their scanner once I get there, but can't see the faults, only see a Map Sensor no signal fault.
I even had their head mechanic take the car home and see if he can get the faults to come back, and they can't. Their recommendation is to replace the ECM, which I need to pay for since there is no fault showing to replace the ECM and the dealer doesn't want the warranty company to question why they are replacing it and find out it's TD1.
As my first Audi, this has been a horrible experience and I have no idea how to actually fix this issue. It's been to the dealership 3 times for the same issue, that they can't see so they can't fix it, yet I can read the faults with Vagcom, and I've even showed the service manager the faults on my laptop.
Oaborbag is offline
Old 07-11-2019, 04:51 PM
bpd
bpd's Avatar
Electrical gremlins are the worst. One easy thing to eliminate as a cause is the Battery. Is it the original? If so, that might be an easy fix. Or seeing that a lot of those sensor faults (not all) are at the bottom of the car, was it a victim of a flood? You got a tough one there.
bpd is offline
Old 07-11-2019, 04:56 PM
gk1
gk1's Avatar
Sorry for your troubles. Strange they cannot see the faults that you see. Can you post the faults here it might help someone to diagnose a bit?
Best option I can think of it take it to another dealership although it sounds like that might be an issue for you if the only one you have is the one 300 miles away...
Also, what coolant leak did they fix specifically? Was it a sensor or connector to the transmission that got soaked with coolant?
gk1 is offline
Old 07-12-2019, 07:14 AM
I was thinking and hoping it was the battery after some searching, seemed when batteries are going out they can cause all kinds of issues. I had the dealer test the battery yesterday and they said it was fine. According to the service records the battery was replaced last August. The car sat on the selling dealers lot for about 6 months before I bought it. I looked at the full service history at the dealer that the car is at for repairs, wish I would have known this before I bought it.
I may try taking it to another dealership, I have a different Audi dealership about 60 miles from where I live, issue will be trying to get back home or picked up after I drop it off. I have some of the faults posted over on Audizine, I'll post them here as well.
The coolant leak they fixed sounded like it was under the engine or at least the lower part. I never noticed it because it was dripping on the pan under the engine. Keep in mind this was about 2 weeks after I bought the car.
Oaborbag is offline
Old 07-12-2019, 07:19 AM
Here are the last logs I saved back in June. These faults always show up. The motor mount has since been fixed.
Tuesday,18,June,2019,19:48:44:14210
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: WAUF2AFC9EN152880 License Plate:
Mileage: 58981km-36649mi Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42 44
46 47 52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
VIN: WAUF2AFC9EN152880 Mileage: 58981km-36649miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 B HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0002
Revision: NCH62---
Coding: 0A2500326546000E1000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM40TFS0114G0906014B 001002
ROD: EV_ECM40TFS0114G0906014B.rod
VCID: 211FE4B4A14A922FB13-8074
2 Faults Found:
5649 - ROD - Unknown Error Code
- 00 [109]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 58955 km
Date: 2019.06.16
Time: 12:10:57
Engine speed: 668.50 /min
Normed load value: 16.1 %
Vehicle speed: 0 km/h
Coolant temperature: 102 C
Intake air temperature: 60 C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.041 V
Unlearning counter according OBD: 40
AFS dm: 25.4 kg/h
Median injection timing: 1.167 ms
Engine operating condition: Idling
Engine operating condition-Test_Program_Channel 87: 5
9025 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 00 [101] - Implausible Signal
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 58980 km
Date: 2019.06.18
Time: 19:19:37
Engine speed: 671.50 /min
Normed load value: 13.3 %
Coolant temperature: 92 C
Intake air temperature: 56 C
Voltage terminal 30: 13.994 V
AFS dm: 20.5 kg/h
Median injection timing: 0.808 ms
A/C compressor: load current: act. value: 680.56 A
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 4G9 927 156 C HW: 0B5 927 156 K
Component: 0B5 40TFSINAR H02 0007
Revision: --H02---
Coding: 000001
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL501021 001025
ROD: EV_TCMDL501021.rod
VCID: 353720E405C20E8F7DB-8060
1 Fault Found:
8448 - Implausible Data Received from Engine Control Module
U0401 00 [109] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 58980 km
Date: 2019.06.18
Time: 19:19:38
Engine speed: 658 /min
Transmission input speed: 658 /min
Transmission output speed: 0 /min
Engine torque: 8 Nm
Transmission fluid temperature: 62 C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen offen
Voltage terminal 30: 14.300 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.912 V
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Revision: -------- Serial number: --------------
Coding: 65B65701A66DEA804B00
ASAM Dataset: EV_ESPPremiAU57X 004039
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 3B2336DC23E6D8FF8BF-806E
2 Faults Found:
0787 - Function Restriction due to Implausible Message(s)
U1112 00 [137] - -
[SCL_MO_Motormomente_Invalid]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 78
Mileage: 58335 km
Date: 2019.05.31
Time: 16:55:08
VzRef: 00
Bit Info 1: 00
Bit Info 2: 22
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: EA
Uz: 9E
0732 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[SCL_QSP_Ist_Moment_Error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 78
Mileage: 58335 km
Date: 2019.05.31
Time: 16:55:08
VzRef: 00
Bit Info 1: 00
Bit Info 2: 22
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 01
F-Type: 08
Uz: 9E
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Serial number: 00000000000000
Coding: 7601010102
ASAM Dataset: EV_AdaptCruisContrAU57X 002010
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 2809F990C2706367F6D-807C
1 Fault Found:
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FAULT_CIS_VDC_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 78
Mileage: 58335 km
Date: 2019.05.31
Time: 16:55:08
Control Module temperature: 43 C
Voltage terminal 15: 12.263 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0013
Serial number: 003103140001364
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
ROD: EV_AllWheelDiffeQSPFR.rod
VCID: 270BFAACCF6E6C1FFF7-8072
1 Fault Found:
0377 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[ESP - Steuergert nicht verfgbar DTC_FRAY_ESP_SYS_STATE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 8
Mileage: 58335 km
Date: 2019.05.31
Time: 16:55:08
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008002
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E050F88E0943D573C1-807A
1 Fault Found:
0648 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 78
Mileage: 58335 km
Date: 2019.05.31
Time: 16:55:09
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H03 0015
Revision: -------- Serial number: 00000001026981
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D070884ED92464F05B-8078
1 Fault Found:
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 78
Mileage: 58335 km
Date: 2019.05.31
Time: 16:55:08
Voltage terminal 30: 12.3 V
Internal Fault ID: 188
Network management state: normal
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Open
Status ParkingBrake right: Open
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7601010102
ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
ROD: EV_AdaptCruisContr2AU57X_002.rod
VCID: 2615F7A8C8647517C41-8072
1 Fault Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 78
Mileage: 58335 km
Date: 2019.05.31
Time: 16:55:08
Control Module temperature: 41 C
Voltage terminal 15: 12.295 V
Velocity_vehicle_reference: -0.00 m/s
Address 8E: Image Processing (J851) Labels: 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000121704147
Coding: 04C19A1A0111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
2 Faults Found:
0028 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[ESP_ESP_01_Signal_Error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 78
Mileage: 58335 km
Date: 2019.05.31
Time: 16:55:09
Outside air temperature: 41.0 C
Voltage terminal 15: 12.3 V
Control Module temperature: 42.0 C
0165 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[QSP_Signal_Error]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 78
Mileage: 58335 km
Date: 2019.05.31
Time: 16:55:09
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H07 0008
Revision: 00001001 Serial number: 97812003541301
ASAM Dataset: EV_AEMLearAU64X 002016
ROD: EV_AEMLearAU64X_AU57.rod
1 Fault Found:
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 58335 km
Date: 2019.05.31
Time: 16:55:11
End----------(Elapsed Time: 03:00, VBatt start/end: 12.1V/12.0V)-----------
Oaborbag is offline
Old 07-12-2019, 09:04 AM
m444's Avatar
Originally Posted by Oaborbag View Post
Here are the last logs I saved back in June. These faults always show up. The motor mount has since been fixed......-
I would focus on ECU & TCU electrical connections and the BAP G71 sensor.
Unknown ECU error.... this is different day (June16) than the other errors, but Two days before Transmission and G71 BAP error.The engine is idling.
2 Faults Found:
- 00 [109]
Mileage: 58955 km
Date: 2019.06.16
Time: 12:10:57
These two are the same day (June 18) & time so one of them may be a real error. The engine is idling.
The Transmission implausible Data Received from ECM/PCM "A" looks like a real issue.
1 Fault Found:
U0401 00 [109] - -
Mileage: 58980 km
Date: 2019.06.18
Time: 19:19:38
Voltage_5V_CAN_pressure sensors-Param to DOP: 4.912 V
Mileage: 58980 km
Date: 2019.06.18
Time: 19:19:37
Likely related to Motor Mount same time and day (May31), they should go away after properly clearing, Make sure you clear in each controller Address group.
1 Fault Found:
Mileage: 58335 km
Date: 2019.05.31
Time: 16:55:11
m444 is offline
Old 07-12-2019, 09:19 AM
gk1
gk1's Avatar
It looks like a lot of those faults are just cascading faults because of the ECU/Engine faults.
The main one being the one both you and the dealer already see. The MAP sensor fault. Perhaps their system does not indicate when there are any cascading faults.
So maybe there is a glimmer of hope since they are going to replace the map sensors.
The other fault "5649 - ROD - Unknown Error Code " is an odd one.
The only comment I can make is that your ECU HW p/n seems to be from a 2013 "4G0 906 014 B"...Your 2014 should be like my 2015 "4G0 906 014 E". (Perhaps yours is an early build 2014?) But it is still strange. Especially since there is no WSC.
Revision: NCH62---
If the dealer flashed you back to stock their WSC should be entered into the ECU... Perhaps someone replaced the ECU with one from a 2013 before you got it? It would be an arduous process for sure, but not impossible.
Anyway you should try asking if there are any stock ECU updates that can be applied. Mine is on H62 0006, while yours indicates H62 0002 but I am not sure if those revisions carry over between different ECU box codes.
Another reason I mention this is because your TCU does appear to be up to date as the part number matches mine and you are at the latest rev H02 0007 so it would only be logical that they would update the ECU too.
Or maybe ask them what is the part number of the ECU they want to replace with...if it is "E" then it sure does sound as if someone swapped in a 2013 box since the ECU's are not superseded parts.
Better yet go to their parts dept give them your vin and ask for the part number for the ECU, see what it is, and if it doesn't match then maybe bring that up to the service guys.
gk1 is offline
Old 07-12-2019, 09:20 AM
Could it be bad connections or water got in the connections at some point and caused the issues? The issues all started the day after I took the car through the first car wash when I got it, well 6 days after I got it. The next day all of the faults showed up, and have come back ever since.
Oaborbag is offline
Old 07-12-2019, 09:25 AM
The only comment I can make is that your ECU HW p/n seems to be from a 2013 4G0 906 014 B...Your 2014 should be like my 2015 4G0 906 014 E. (Perhaps yours is an early build 2014?) But it is still strange. Especially since there is no WSC. If the dealer flashed you back to stock their WSC should be entered into the ECU... Perhaps someone replaced the ECU with one from a 2013 before you got it? It would be an arduous process for sure, but not impossible.
Another reason I mention this is because your TCU does appear to be up to date as the part number matches mine and you are at rev H02 0007 so it would only be logical that they would update the ECU too.
Now that is interesting...Not sure why it would have a 2013 ECU in it, even doing a google search of that number brings up 2013 Audi ECU. I'll ask the dealership about this when they call me today, maybe they can replace that or do something under warranty, just hoping at this point to not have to spend a lot of out of pocket money to fix the car since I did purchase the warranty.
Oaborbag is offline
Old 07-12-2019, 09:28 AM
One thing I'd add that just came to mind, Is I remember when going through the service history, one of the first items the first owner had done was replace the transmission. I don't have the records on me so I can't see the date or part number associated with it, but maybe the car was an early 2014 and thats why the TCU matches your 2015?
Oaborbag is offline
Quick Reply: Multiple Faults, Dealer can't replicate
