S6 (C7 Platform) Discussion Discussion forum for the C7 Audi S6 produced from 2012 - 2017
Which Nav Version or MMI unit do I have??
Old 11-06-2018, 05:19 PM
Mr. Scary's Avatar
Default Which Nav Version or MMI unit do I have??
Hi Guys,
Which Nav version is this and can I upgrade either the version or the maps to something newer than 2013? Or the main MMI P0609 version to a newer version?
I need to know what exact model of MMI or RMC I have???
Because there are 2 choices of the Video in Motion on the OBD11, one is for MMI and one is for MMI RMC?
Software is HN+R_US_AU_P0609 Also if there is an easy way to update the navigation version, please let me know.
Old 11-06-2018, 05:48 PM
superswiss's Avatar
Received 1,065 Likes on 740 Posts
You have the MMI 3G+, not RMC. You are running a very old firmware. There are dealer firmware upgrades. The latest one is 0942_x. Not sure exactly which patch version is the latest. I'm running 0942_3 if I remember correctly. Got it installed about 2 years ago. There hasn't been a major new update as the system is end of life. Map updates continue to come out. There's usually one every 6 months. Officially, firmware and map updates can only be performed by a dealer. Map updates can cost as much as $400 for the map data plus labor. There are some grey market sources and you can find firmware updates on eBay if you are technically inclined to perform the update yourself. You also have older hardware, so you are only getting a 2G signal for Audi connect. Audi offered a telephone module upgrade to original owners to restore the 3G signal after T-Mobile refarmed their network and also added support for AT&T. I believe the part is discontinued now, though.
Old 11-06-2018, 05:54 PM
raj99's Avatar
+1 on the above. I've got the latest 2019 maps on my D4 3G+ MMI and running 6.18.2 version. Your firmware will need to be updated first, since that's also the original from the factory.
Old 11-06-2018, 08:05 PM
Mr. Scary's Avatar
Thank you for the help and knowledge. Yes I am looking at non dealer options to upgrade the firmware and maps. I'd like to find out about the telephone upgrade as well
iconoclast
Q7 MK 1 Discussion
43
02-23-2021 07:42 PM
cmwerner
03-05-2009 05:08 PM
quattrogirl
06-04-2008 12:20 PM
05whtaudia6
03-16-2008 07:14 AM
JDoe62
Q7 MK 1 Discussion
12-27-2006 06:26 AM
Quick Reply: Which Nav Version or MMI unit do I have??
