S6 (C7) brake pad & caliper - where to buy
I finally wore down my front breaks (at 30k miles). What's the best place to buy the pads & calipers (and sensor) to have an indy shop install them? I'm trading (or selling) the car soon, but I don't want to give anyone a car with worn breaks anyway, so I think i'll have to bite the bullet and replace them.
You don't need to replace the caliper, since it's the big black thing that fits over the rotor (which holds and squeezes the brake pads). I bought pads, shims and sensor from a dealer but others have found aftermarket pads that work. The job isn't that hard to do yourself with basic hand tools. There's a DIY thread in this section.
Thanks for the info! How much did the dealer charge you? My dealer said I need rotors since the breakpad was so worn down - any truth to that? I'm being quoted $2k for parts & service for JUST the front brakes/rotors. Seems pricey, but I got a similar price at another audi dealership too.
I'm in Canada, so the amount I paid won't really apply to you. Have a look at my DIY thread here, as it has some pricing information. If you allowed the brake pads to wear down to the backing plates, then your rotors are likely scored and will either need to be turned or replaced. If you're not at that point, then there's a good chance that they'll be fine to re-use. Mine were well within spec, but it's best to measure yours to be sure.
The Front discs are $330 each MSRP, 4H0-615-301-AL Rotor 400MM BRAKES, online $248.82 here:https://www.audiusaparts.com/auto-pa...omponents-scat
Front Brake Pads 4G0-698-151-AB MSRP $290.00, online $222.43
Caliper mount mount bolt N91147601, MSRP $6.40, online $4.13 each (need four)
Audi Disc Brake Pad Shim Front (A8 Quattro S7 S8 S6) - Genuine VW Audi 4H0698231, MSRP $268.00, online $161.79, here: https://www.fcpeuro.com/products/aud...-vag-4h0698231
Front brake parts are about $1273 MSRP
Sounds about right then. They are quoting 4h of labor (which is $700) + tax. Some good savings if I buy it myself and have an indy shop install though, right?
There here are other front pad options such as these which are $82 cheaper:
2016-AUDI-S6 Disc Italia Titanium Kevlar Front TK1575 $140.00 Brake Pads-CHROMEBRAKES,DISCITALIA,DISCITALIA,FERODO RACING,HAWK ,HAWK ,ROTEX,XBRAKES,XBRAKES,- Brakeworld
It's not possible, as it's a closed monobloc caliper design (i.e. no removable bridge to facilitate quick pad changes, a feature of many race-oriented calipers). Even current Porsche GT cars suffer from the same limitation, even though they are warrantied for track use.
q5newbie
Q5/SQ5 MKI (8R) Discussion
10
06-01-2012 09:35 AM
