Presenting the new AWE Audi C7 4.0T S-FLO Carbon Intake!
Audiworld Basic Sponsor
Presenting the next generation of the AWE S-FLO Carbon Intake for Audi C7 S6/S7 and RS6/RS7:
- Proven power on Stage 1 and Stage 2 cars, with and without downpipes
- Max gains of 32 hp and 50 ft-lbs of torque @ 3150 rpm, crank (RS7, Stage 2 software + downpipes)
- Max gains of 15 hp and 27 ft-lbs of torque @ 2670 rpm, crank (RS7, stock software)
- Max gains of 24 hp @ 3250 rpm and 36 ft-lbs of torque @ 3150 rpm, crank (S6, Stage 2 software + downpipes)
- Max gains of 15 hp and 19 ft-lbs of torque @ 4020 rpm, crank (S7, Stage 1 software)
- Completely redesigned to support higher power applications
- Durable and washable high-flow AWE S-FLO Filter included
- Perfect integration with OEM inlet ducting
- Smooth transitions from full carbon fiber airbox inlet and turbo inlets
- Retains stock mounting locations
- UV-stabilized resin and clear coat
- Perfect fitment - guaranteed
- No Check Engine Light Guarantee
Full floating carbon construction, no silicone. The AWE C7 4.0T S-FLO Carbon Intake features full carbon fiber construction allowing smooth transitions of airflow from the grille inlet to the turbo inlets. By deploying a new grille-mounted air box inlet, and utilizing the factory accordion turbo couplers, the S-FLO Carbon Intake floats in place under heavy torque situations, preventing strain on the carbon fiber.
In other words, this box has both the looks and performance to earn the AWE S-FLO badge.
The S-FLO Filter:
The included AWE S-FLO Filter is designed specifically for the AWE C7 4.0T S-FLO Carbon Intake to ensure easy service and to maximize airflow by sitting in the direct path of ram air from the grille. The combination of S-FLO carbon airbox and included S-FLO Filter makes for a more aggressive intake note, with a distinctive turbo spool sound when under boost and letting off of the throttle.
Power testing:
The AWE C7 4.0T S-FLO Carbon Intake has been power and quality tested on the stock setup as well as under aggressive stage two conditions which incorporated high-flow downpipes. The AWE C7 4.0T S-FLO Carbon Intake produced healthy gains in all scenarios, and has withstood long-term real-world testing for quality and performance.
Add in our new enlarged, integrated honeycomb-meshed port located on the top of the S-FLO’s air box, and you’ve got optimal airflow even when pushing higher-than-stock boost levels.
Data - RS6/RS7:
Data - S6/S7:
You’ve got questions? We’ve got answers. 1.888.565.2257, 215.658.1670 or performance@AWE-Tuning.com.
Josh Davis > Performance Specialist
AWE-Tuning.com > 1.888.565.2257
my email > facebook > twitter > instagram > youtube
AWE S-FLO Carbon Intakes are back in stock with limited quantities available. Get yours right this way.
Showin' off the AWE S-FLO Carbon Intake with @audivwxotics. Photos by @wtrandy. Learn more right this way.
Receive 15% off all AWE Audi products, valid through participating AWE dealers and awe-tuning.com. Get started right this way.
It's time to secure your deal. Until December 3, receive the following discounts on AWE Audi products:
• 20% off MSRP on the AWE S-FLO Carbon Intake Suite for the Audi B8/8.5 S4/S5 3.0T.
• 20% off MSRP on AWE Intercooler Kits for the 2.7TT.
• 15% off MSRP on all other AWE Audi products.
Valid through participating dealers and at awe-tuning.com. Get started right this way.
Receive the following discounts on AWE Audi products:
Valid through participating AWE dealers and at AWE-Tuning.com. Get started right this way.
Freshly-installed AWE S-FLO Carbon Intake, courtesy of Open Road Tuning. Get more details right this way.
