It rained.. and this is how my car responded..
So I live in Saudi where it rarely rains, but when it does we do get a lot of water on the roads because of the drainage system. Anyways, I had to pass a patch of water until half or less than half of my wheels, the car drove fine all the way till I reached home and I was very happy that she didn't betray me.
Until the next morning when I started my car and got a Christmas tree on my dashboard:
- TPMS, Tire Pressure System Fault
- Parking Brake Fault
- Air Suspension Fault
- Stabilisation Control: (ABS / ESC) Fault
I called my SA immediately and he said from their experience, just leave the car in sun for a day or two and it should clear on its own. It did!
however it returned back again after 3 days and now it just won't go away.
(might not be related):
Also now I get the "Do Not Exceed 4000 RPM" message which is "P2004 / 6" code "Intake manifold flap stuck open / close
I am not sure if its related or that's something on its own
Anyways, here is the scan from my OBDELEVEN after clearing many codes but these won't go away at all, any input or advise would be highly appreciated.. Thanks
OBDeleven data log
Date: 2018-11-02 22:14
Car: Audi S6
Year: 2013
Body type: Saloon
Engine: CEUC 309 kW (420 HP) 4.0 l
Mileage: 79754 KM
01 Engine
System description: 4.0l V8TFSI /
Software number: 4G0906014
Software version: 0012
Hardware number: 4H0906014
Hardware version: H56
ODX name: EV_ECM40TFS0114G0906014
ODX version: 001014
Long coding: 0A2500326526010A1000
Trouble codes:
No trouble codes found
02 Transmission
System description: 0B5 40TFSIRdW
Software number: 4G1927156L
Software version: 0011
Hardware number: 0B5927156K
Hardware version: H07
ODX name: EV_TCMDL501021
ODX version: 001025
Long coding: 000001
03 Brakes
System description: ESP PREMIUM
Software number: 4G0907379H
Software version: 0361
Hardware number: 4G0907379H
Hardware version: H09
Serial number: --------------
ODX name: EV_ESPPremiAU57X
ODX version: 004028
Long coding: 65A6C701A665E380CB00
Trouble codes:
U111300 - Function limitation due to received malfunction value
static
C101A01 - Left front ABS wheel speed sensor Electrical error
static
04 Steering Angle Sender
05 Kessy
System description: BCM2 2.0
Software number: 4H0907064DT
Software version: 0510
Hardware number: 4H0907064CT
Hardware version: H32
Long coding: 05882F46000000000000
08 Air Conditioning
System description: KLIMA 4 ZONEN
Software number: 4G0820043AD
Software version: 0070
Hardware number: 4G0820043AD
Hardware version: H13
Serial number: 05071200040779
ODX name: EV_AirCondiComfoUDS
ODX version: 002036
Long coding: 680120783D
09 Central Electrics
System description: BCM1 2.0
Software number: 4H0907063CG
Software version: 0130
Hardware number: 4H0907063
Hardware version: H12
Serial number: 00000001545298
Long coding: 0907201009749FE0898100C4A0001800CF9CC3082E08020180 0108546F01
Subsystems:
System description: WWS57X 120606
Software number: 4G1955119
Software version: 0080
Hardware version: H36
Serial number: 120620163850
Long coding: 0045F7
System description: G397_RLFS
Software number: 8U0955559B
Software version: 0002
Hardware version: H06
Serial number: 20396879
Long coding: 02006D
System description: E1 - LDS
Software number: 4G0941531G
Software version: 0044
Serial number: 28 06 2012 00001302
System description: A31 LED Mod1L
Software number: 4H0907472B
Software version: 0006
Hardware version: H03
Serial number: 00000010071200010821
Long coding: 110000
System description: A27 LED Mod1R
Serial number: 00000017121300010067
Long coding: 110000
System description: EVLS-SG
Software number: 4H0907705K
Software version: 0300
Hardware version: H08
Serial number: WA103815000001527270
Long coding: 020300
System description: AQ_Hum_Sensor
Software number: 4H0907658
Software version: 0003
Serial number: 6F180936000000000001
Trouble codes:
10 Parking Assistance 2
System description: PARKHILFE ACC
Software number: 4H0919475AG
Software version: 0072
Hardware number: 4H0919475AG
Hardware version: H01
Serial number: 61061219101181
ODX name: EV_EPHVA18AU57X0000
ODX version: 003008
Long coding: A8E30A
15 Airbag
System description: Airbag10.43
Software number: 4H0959655C
Software version: 0040
Hardware number: 4H0959655C
Hardware version: H43
Serial number: 003JG009DWPV
ODX name: EV_AirbaAU10BPAAU64X
ODX version: 001014
Long coding: 30323436313330303432554A304C34473053
Trouble codes:
U112300 - Databus error value received
static
16 Steering Column Electronics
System description: Lenks.Modul
Software number: 4H0953568G
Software version: 0005
Hardware number: 4H0953568G
Serial number: 90372LFT001UM
Long coding: 0000F4
17 Dash Board
System description: TBenRdw Nv
Software number: 4G0920930R
Software version: 0515
Hardware number: 4G0920930R
Hardware version: H76
Serial number: 6581107125960316
ODX name: EV_RBD4K
ODX version: 004046
Long coding: 53AF09011B510008010200
19 Gateway
System description: J533--Gateway
Software number: 4G0907468AB
Software version: 0028
Hardware number: 4G0907468AA
Hardware version: H10
Serial number: 00000000598823
ODX name: EV_GatewPkoUDS
ODX version: 001013
Long coding: 00ED074800
20 High Beam Assistance
System description: FLA
Software number: 8T0857511AD
Hardware number: 8T0857511AD
Hardware version: H04
Long coding: 04018264747464545425363E00
28 Climate Control Unit Rear
System description: KLIMA FOND
Software number: 4G0919158J
Hardware number: 4G0919158J
Serial number: 12071200040542
ODX name: EV_ClimaContrUnitRearUDS
ODX version: 002018
Long coding: 20
34 Ride Control System
System description: LUFE-DAEMPFER
Software number: 4G0907553F
Software version: 0782
Hardware number: 4G0907553F
Hardware version: H18
Serial number: �‰ xe
ODX name: EV_AirSuspe
ODX version: 003024
Long coding: 008000
Trouble codes:
36 Seat Adjustment Driver Side
System description: MEM-FS
Software number: 4G8959760
Software version: 0154
Hardware number: 4G8959760
Serial number: 00000033479737
Long coding: 00581B0000006001000001010101102030303232203232
3B Sensor Electronics
System description: SARA 6D
Software number: 4G0907637K
Software version: 0053
Hardware number: 4G0907637F
Hardware version: H02
Serial number: EJ1BPA8200HCF5����������
ODX name: EV_SARA2
ODX version: 005011
42 Door Electronics Driver Side
System description: TSG FA
Software number: 4G8959793J
Software version: 0506
Hardware number: 4G8959793G
Long coding: 011F16005E00628002080002
44 Steering Assistance
System description: RCEPS
Software number: 4G0909144L
Software version: 0010
Hardware number: 4G0909144G
Hardware version: H35
Serial number: 0022672695
ODX name: EV_RCEPS
ODX version: 009008
Long coding: 101001010000
46 Central Module Comfort System
Serial number: 0179746203
Long coding: 011A0E2000B93185833008800A030300000000000000000000 0000000000
47 Sound System
System description: BOSE-G3C7-ANC
Software number: 4G1035223A
Software version: 0540
Hardware number: 4G1035223A
Serial number: 00000000001816
Long coding: 030000
52 Door Electronics Passenger Side
System description: TSG BF
Software number: 4G8959792J
Hardware number: 4G8959792G
53 Parking Brake
System description: EPB-4
Software number: 4H0907801F
Software version: 0013
Hardware number: 4H0907801A
Serial number: 00000000405934
ODX name: EV_ParkiBrake
ODX version: 001027
Trouble codes:
static
55 Headlight Regulation
System description: ....LWR12....
Software number: 4H0907357A
Hardware number: 4H0907357A
Serial number: 120711-0004-1590
ODX name: EV_HeadlRegulBasic
ODX version: 005001
Long coding: 11216F601002A300
56 Radio
System description: Radio U Basic
Software number: 4G1035053G
Software version: 0121
Hardware number: 4G1035053
Hardware version: H41
Serial number: 227G10C7609763
Long coding: 070003010000000001
5F Information Control Unit
System description: H-BNT-RW
Software number: 4G0035764F
Software version: 0637
Hardware number: 4G0035764H
Hardware version: H49
Serial number: 192GW0C7500553
Long coding: 060D00000203F5EF4D90CB2E00000003740001020000000000
Subsystems:
System description: ROW 2012
Software number: 8R0060884AJ
Software version: 0403
System description: DU8 C7 SV
Software number: 4G0919605B
Software version: 0021
Hardware version: H42
Serial number: AUZ8ZDC9401WK5%
System description: E380 BDT C7
Software number: 4G1919612Q
Software version: 0204
Hardware version: H11
Serial number: 90349LFR00158
System description: CD-Database
Software number: 8R0060961C
Software version: 3638
Trouble codes:
62 Door Electronics Rear Left
System description: TSG HL
Software number: 4G8959795J
Hardware number: 4G8959795G
Long coding: 010F14004000628002080002
6C Camera System Rear View
System description: TopView
Software number: 4H0907428A
Software version: 0111
Hardware number: 7P6907441D
Hardware version: H05
Serial number: 82330JF0048302
ODX name: EV_CamerSysteTopViewAUDI
ODX version: 005022
Long coding: 0201000001010000000102000000
6D Deck Lid Control Unit
System description: HDSG-Modul
Software number: 4G5959107A
Software version: 0038
Hardware number: 4G5959107
Serial number: 146200729
ODX name: EV_HDSGAu571
ODX version: 001001
Long coding: 111104C000
72 Door Electronics Rear Right
System description: TSG HR
82 Head Up Display
System description: HeadUpDisplay
Software number: 4G0919604G
Software version: 0106
Hardware number: 4G0919604G
Hardware version: 006
Serial number: 00000000000000
ODX name: EV_HUDContiC7
ODX version: 001020
Long coding: A60000
85 On-Board Camera
System description: DPC-SG
Software number: 4G0907217A
Hardware number: 4H0907217A
Hardware version: H25
Serial number: 26213002542100000249209769
ODX name: EV_OnBoardCamerDPC
ODX version: 001007
Long coding: E2040000
8E Image Processing Electronics
System description: BV-SG
Software number: 4G0907107D
Hardware number: 4H0907107
Hardware version: H30
Serial number: 00500005060712769104590000
ODX name: EV_BC7
ODX version: 001001
Long coding: 04408A180111
8F Pretensioner Front Left
System description: RGS-VL
Software number: 4H0980945B
Hardware number: 4H0980945B
ODX name: EV_RGS_L
ODX version: 002004
Long coding: 00060000031F030000030801424CDA010000
90 Pretensioner Front Right
System description: RGS-VR
Software number: 4H0980946B
Hardware number: 4H0980946B
ODX name: EV_RGS_R
ODX version: 002004
A9 Actuator For Structure-Borne Sound
System description: SAS-GEN 2
Software number: 4G0907159B
Hardware number: 4H0907159A
Serial number: 120620201224
ODX name: EV_SoundActuaGen2AU64X
ODX version: 003010
BA Assembly Mounting
System description: AEM - LEAR
Software number: 4H0907145
Hardware number: 4H0907145
Serial number: 97804000421104
ODX name: EV_AEMLearAU64X
ODX version: 002014
OBDeleven data log
Car: Audi S6
Year: 2013
Body type: Saloon
Mileage: 79754 KM
01 Engine
ODX version: 001014
Trouble codes:
02 Transmission
ODX version: 001025
Long coding: 000001
03 Brakes
ODX version: 004028
Trouble codes:
static
static
05 Kessy
08 Air Conditioning
ODX version: 002036
Subsystems:
Long coding: 0045F7
Long coding: 02006D
Long coding: 110000
Long coding: 110000
Long coding: 020300
Trouble codes:
ODX version: 003008
Long coding: A8E30A
15 Airbag
ODX version: 001014
Trouble codes:
static
Long coding: 0000F4
17 Dash Board
ODX name: EV_RBD4K
ODX version: 004046
19 Gateway
ODX version: 001013
ODX version: 002018
Long coding: 20
ODX version: 003024
Long coding: 008000
Trouble codes:
ODX name: EV_SARA2
ODX version: 005011
ODX name: EV_RCEPS
ODX version: 009008
47 Sound System
Long coding: 030000
53 Parking Brake
ODX version: 001027
Trouble codes:
static
ODX version: 005001
56 Radio
Subsystems:
Trouble codes:
ODX version: 005022
ODX version: 001001
82 Head Up Display
ODX version: 001020
Long coding: A60000
85 On-Board Camera
ODX version: 001007
ODX name: EV_BC7
ODX version: 001001
ODX name: EV_RGS_L
ODX version: 002004
ODX name: EV_RGS_R
ODX version: 002004
ODX version: 003010
ODX version: 002014
Most likely something got shorted. Not a good idea to drive these cars through that much water. There was a similar recent post somewhere on this forum about a steering module fault after driving through a puddle. I believe the poster is from your neck of the woods. Must have been the same rainstorm. He got water into the power steering module and it shorted, so he's looking at having to replace the entire steering rack. There is too much sensitive electronics in this car for stunts like that. Water up to half of your wheels is no good. That's like driving through a mild river. Not for a car like this. I guess you were lucky that the the water didn't swell up from passing cars over your hood line and getting sucked into the intake causing engine hydrolock, but you may have scooped up water with your front and gotten it into places where it's not supposed to go.
Looks like the only real fault you have is for the wheel speed sensor. If the fault won’t clear then you can try to swap it from left to right and see if the fault follows. Your steering rack (44) is communicating with no faults so I’m sure you’re good there. These modules rely on messages from each other so if one gets a fault then multiple will throw faults depending on the issue.
scissorfighter
Q5/SQ5 MKI (8R) Discussion
03-24-2019 05:35 AM
jimmyw
10-14-2014 07:13 AM
