Severe vibrations when doing U turns
I have a 2016 Model S6 with 15K miles. When I execute slow U turns in any direction there is severe vibration and grating sounds that I can feel and hear. The Audi technician says its a designed in feature that has to do with the way the differential is designed to work and that this occurs on all Audi S6 cars, and other Audi's that have a sports suspension. Has anyone experienced this, and more importantly have you found a solution?
Audi Quattro models don't particularly like doing 'full lock' turns, including U-turn type scenarios. The longer the wheel base, the more pronounced this becomes.
If you back off the lock slightly, does it get less severe?
I wouldn't classify the vibration as severe, but some binding in sharp turns is normal for a car with a Torsen or Crown-gear center diff. Nothing to do with the suspension.
'totally' normal and like mentioned, quattro. In a way i do think suspension also comes bit in the play, not directly but the stiffer the more it will translate (R8 for example is even worse at sharp U turns).
Wheel size
I get vibrations and noise with my 20"
wheels but much less (almost none)
with the 19". What size wheels do you have?
I do have to give credit for the good advice that I got to do this on this forum.
NJTTguy
07-20-2017 01:28 PM
zarmstrong92
A6 (C7 Platform) Discussion
07-11-2017 02:20 PM
Gilbertorodz
06-14-2017 09:38 AM
