Sports Differential System Fault
Hi guys, there is a big problems with my 2013 S6. I had these error pop up in yellow after I used water blaster to wash my car. I tried re-start my car and all of them gone, but when I drove like 10 meters they came up again. Had tried couple times but same results. Does anyone know what's wrong with it? Did I wash my car too hard? Thanks
Did you use the spray washer under the hood of the car? If so, you probably got some of the electronics and/or connectors wet. You'll have to go in a dry them all, in turn, until you stumble upon the offending party. Might need to add some dielectric grease.
Hi mate, thanks for your help and I just got some message from my machinist today. There is no feedback from my front left wheel suspension and all the problems duo to ABS system. Probably I wash my wheels too "hard" and I damaged the ABS computer or the wires got wet. He also has no idea right now, will check all the wires one by one tomorrow.
A commercial washer shouldn't do any of that if you didn't spray the engine compartment. I've sprayed all around the brakes from inside the wheels, and all around the tire inside the fender with the gun at full blast, and no errors... at least yet. He he. The other problem with Audi is you get a ton of unrelated faults, so you need to get all codes and try to guess what the heck 'failed', causing all the other codes. Really frustrating. Having said that, let's analize your faults: ESC, air suspension, sport differential, and start/stop. The only fault that makes sense to trigger the other 3 is the air suspension, so that's probably your only issue. Once you fix that, all others should clear. I messed up an air suspension lowering job, and got all of those faults plus a few more, like headlight range, adaptive cruise, etc. When dealer recoded the suspension module, all other codes cleared, as expected. Good luck.
Bruno_S4
Canadian Discussion
17
05-11-2008 06:22 AM
RichieB5
09-03-2005 10:56 AM
roman_0028QMS
19
07-04-2005 05:32 PM
acett
10
01-27-2003 07:39 PM
Chard
01-21-2001 07:50 PM
