First time vag com fault codes c7.5 s7
Just ran vcds for first time... Wondering if there is advice for the rare fault codes I got... This us the danger of having instruments and not knowing how to use them lol
Address 01: Engine (------CTGE) Labels: None
Part No SW: 4G0 906 014 D HW: 4H0 906 014
Component: 4.0l V8TFSI / H63 0001
Revision: NCH63---
Coding: 1A2500326546010E3000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114G0906014D 001001
ROD: EV_ECM40TFS0114G0906014D.rod
VCID: 230626E02A4C0F2643-8076
1 Fault Found:
19407 - Partial engine operation
P166F 00 [032] - Deactivated
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Revision: -------- Serial number: --------------
Coding: 65BED44BA67D2BD21B00
ASAM Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41CA8C68D0103D3631-8014
2 Faults Found:
161024 - Tire Pressure Warning
C102D 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 1032 km
Date: 2016.04.10
Time: 18:07:48
161792 - Tire Pressure Warning
C102D 00 [032] - -
Freeze Frame:
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000002028283
Coding: C0ED074814
ASAM Dataset: EV_GatewPkoUDS 001028
ROD: EV_GatewPkoUDS.rod
VCID: 3B36FE80B2FC57E66B-806E
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 9461618103
Voltage stabilizer:
1 Fault Found:
12291 - Energy Management Active
U140B 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 117
Mileage: 1371 km
Date: 2016.04.15
Time: 16:53:51
Thanks in advance!
Andrew
Revision: NCH63---
1 Fault Found:
Freeze Frame:
2 Faults Found:
C102D 00 [040] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 1032 km
Date: 2016.04.10
Time: 18:07:48
C102D 00 [032] - -
Freeze Frame:
Coding: C0ED074814
Voltage stabilizer:
1 Fault Found:
U140B 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 117
Mileage: 1371 km
Date: 2016.04.15
Time: 16:53:51
Thanks in advance!
Andrew
I'm knew to Audi. But I feel comfortable in saying if the engine light does not come on and you do not notice any issue with your car there is likely not one. If something consistent develops these are used to assist the repair guy in determining the problem with your car. It's good information but not in a vacuum. Right now just unmeaningful hiccups.
HellooMcFly
11-10-2008 07:31 PM
SOLD2000-1.8TQMSport
11-08-2004 12:04 PM
